Deckel FP3-50 Dialog 12, start up problems
Likes Likes:  0
Results 1 to 1 of 1
    May 2016
    NETHERLANDS
    Default Deckel FP3-50 Dialog 12, start up problems
    Hello,
    I own a Deckel FP3-50 with Dialog 12 on it since a time now.
    When I buy machine it stood still for a long time, and it wouldn't pass the self test by startup.
    I replaced the 3 batteries for new ones and machine start up till display with x,y,z on it but doesn't work further.
    All parameters where out but luckily I have them on disk and printed.
    At that time I had not enough time to insert parameters and machine wasn't at his final place.
    So it stand for about a half year. Now it moved to it's final place and I want to start it up again and insert parameters to get the machine working.
    But now I have the following problem:
    Machine start up and goes thru the self test, all ok.
    After that screen stops at and only display "CMOS CHECKSUM OK" (See attached picture 1)
    In the cabinet I see on the right side on display "F.2" It should count to F.1 and then to 0.0 in my opinion.
    And on the card NPP 04A the LED Error blinks. I have checked this during start up and when machine is in self test the LED Run blinks but immediately after self test it goes to Error.
    Does anyone has an idea what this problem could be?
    An is it possible to insert parameters in this way? I think maybe parameters will cause the problem.
    I hope someone can help me, thanks in advance.
    Albert
