Peter from Holland
- Jan 15, 2005
- The Netherlands
We bought a nice Deckel FP3 in the North of France in December last year
It took a while to get it here but when it arrived we were very pleased with it at first
It was one of the later ones with only a single motor Identical like on the active FP3
Typicly the Z handwheel on these is not at a angle but vertical
While cleaning we noticed the Z axe did not move up or down manualy WTH
The powerfeeds and rapids did work though
So we took of the casting directly behind the handwheel
Nothing wrong there When we turned the little wheel further up the geartrain the saddle did not lower or rise
Well Things got worse We had to remove the saddle from the main body
Got the scales on the Y removeded Also the trip dogs and the scrapers on the Y and Z Then turned the Y all the way back Spindle out of the nut and a bit more by hand
Turned the angle head 90 dgr and slide it all back
Then loosened the back gibs a bit and removed the tapered gib
The bolts that held the Z-axe spindle nut were removed (That works better as turning the saddle all up out of the nut of the feed spindle )
Here you see it lifted up
We removed the cover and there it was
The shaft holding the bevel gear broke off
On the drawing its shaft 2201-2220
We see if we can get that shaft out tomorrow
Anybody done that before ??
