Deckel FP3L questions
Results 1 to 15 of 15
    Nov 2003
    Phelps, NY, USA
    1,690
    1144
    350
    Default Deckel FP3L questions
    I may be looking at an older, grey, FP3L. The serial number is 1741. About how old would it be.
    The machine doesn’t include an overarm bracket or arbor for horizontal milling. Are these hard to find?
    What is the collet type on this vintage machine? They look a little different than standard 40 taper tools (but that could be a bad angle for the pictures).
    Finally, for someone who grew up on Bridgeport style mills, how easy is it to get used to working from the side/rear of table with a fixed table, traveling column machine?
    I like the flexibility of the table design and am intrigued by a fixed table, but have to confess that the operator position is throwing me off a little.
    Dec 2002
    Benicia California USA
    8,817
    2322
    3229
    Overarm fit up is the same as the other manual Deckel mills...Same size dovetail, so overarms are out there,
    Nothing special with the arbors. Just have to have a style of end bearing that agrees with your outboard support bearing.
    Both spindles (horiz and vert) are standard #40 , but the drawbars are different and so the collet or tool holder if you use the standard draw bar,
    Normal Deckel practice is 20x2.0 "Buttress" male thread on collet /tool holder or arbor.
    Can change the drawbar to accept more standard tooling...Can also adapt industry standard "CAT" or "BT" holders with an appropriate stud to work with the factory draw bar.
    Working position can take a bit to get used to if you have lots of "seat time" using a more conventional (ie Bridgeport) mill....It will grow on you.
    Long parts will take some adjustment as it will be working away from you., and not across as you are more used to....
    Can be some things to consider:
    Vertical moves will because of the weight of the moving parts feel heavier than other style machines,,,
    Geometry on a well used machine might be somewhat compromised....Wear on the "X" axis will tend to make the vertical casting slope toward the front of the machine affecting the
    truth of both the "Z" and "Y".....
    They are great for large and heavy parts....
    Cheers Ross
  3. Likes AndyF liked this post
    GERMANY
    3,677
    2465
    1486
    Quote Originally Posted by AndyF View Post
    If you can't find one in the USA, overarms and bearings for horizontal milling, that will fit an FP2/3 are often up for sale on German Ebay. These typically cost around 200 Euros for the set. Should be shippable to the USA for around that same cost, maybe a bit less.
    In German these are called "Gegenhalter" and "Gegenlager". Here are some search results:
    https://www.ebay.de/sch/i.html?_from...alter&_sacat=0
    https://www.ebay.de/sch/i.html?_from...eckel&_sacat=0
  5. Likes AlfaGTA, Milacron, mark in Portugal, AndyF liked this post
  6. #4
    Jan 2003
    Imlay City, Michigan
    2,269
    132
    274
    I have several over arms available, no arbor supports.........
    Kevin
  7. Likes ballen, AndyF liked this post
  8. #5
    Mar 2015
    GREECE
    738
    272
    203
    Hi to all,
    unless I am mistaken, Deckel never provided any overarms for the FP3, it was that vertical head that doubled as such. (not that an FP2 overarm wouldn't fit though).
    So, if you have the vertical head you also have an overarm. Regarding the support, it's a fairly straightforward project to build one, especially on a machine with a horizontal quill!
    BR,
    Thanos
  9. Likes Peter from Holland, AndyF liked this post
  10. #6
    GERMANY
    3,677
    2465
    1486
    Hi Thanos,
    Quote Originally Posted by thanvg View Post
    Unless I am mistaken, Deckel never provided any overarms for the FP3, it was that vertical head that doubled as such. (not that an FP2 overarm wouldn't fit though).
    If that's right, then all that the OP needs is one of these, which can probably be shipped to the USA at reasonable cost, because it's not that heavy, and quite compact:
    Gegenlager fur Gegenhalter Deckel FP3 Universalfrasmaschine RHV7766 | eBay
    Gegenhalter von Deckel FP Maho Gegenlager TOP | eBay
    Gegenlager fur Gegenhalter O17mm Deckel FP Universalfrasmaschine | eBay
    Last of these has a bad paint job, looks like a good deal (but note that I have no relation to any of these sellers).
    Cheers,
    Bruce
  11. #7
    Jan 2005
    The Netherlands
    6,806
    378
    2022
    Quote Originally Posted by ballen View Post
    Hi Thanos,
    Cheers,
    Bruce
    When I clicked on those links I got this message
    The website you just visited provides you with access to products, offers and services from brands you love. This website has partnered with us, CJ Affiliate/Conversant, for the use of our advertising and analytics technologies (including cookies). In other words, the website owner may earn a commission when you make a purchase from a brand they help connect you with. We use these technologies to collect data to better understand your browsing activity on this site and other third-party websites and apps. We use this data to serve you with interest-based advertising and for analytics purposes, and may share this data with our service providers for those same purposes.
    By clicking “Continue to Site” or clicking the “X” to close this banner, you are providing consent to the use of advertising and analytics technologies (including cookies) on this site and other sites that work with us. If you wish to decline, click “Learn More” below.
    Why ????
    Peter
  12. #8
    GERMANY
    3,677
    2465
    1486
    Hi Peter,
    Quote Originally Posted by Peter from Holland View Post
    <SNIP>
    Why ????
    I don't know. When you look at the content of my post (visible when you do "reply with quote") you will see that I have only embedded the ebay links, nothing else. A possible solution/workaround for you:
    (1) Do "reply with quote" to my earlier message
    (2) Find the ebay links
    (3) Cut and past link into a new tab or window on your browser
    Good luck!
    Bruce
  13. #9
    Mar 2015
    GREECE
    738
    272
    203
    Wondering what those links led to Bruce, can't open them either.... I'll try from home as well.
    (if it's only the bearing support at the end of the overarm, then yes, he'll need it!)
  14. #10
    Sep 2002
    Salinas, CA USA
    4,840
    540
    447
    When I click on the first link it takes me to www.qksrv.net/media/offers/?AID=11873549&PID=100203028&SID=PM-Forum with a message the offer could not be found.
  15. #11
    Aug 2012
    California, Central Coast
    5,361
    2405
    2212
    The ebay links did not work for me either. Clicked directly on post #6.
  16. #12
    GERMANY
    3,677
    2465
    1486
    I'll write to one of the people who maintains the PM web site and ask about this. When I click on the links in post #6, they immediately take me to the correct place.
  17. #13
    May 2018
    CANADA
    Quebec
    241
    237
    76
    The first link goes to "https://redirect.viglink.com/?format=go&jsonp=vglnk_162585947200313&key=e813d01 7cbaa4f81b8c533d5382e65a2&libId=kqwqihmi0100pcxy00 0DLj3isjn0q&loc=https%3A%2F%2Fwww.practicalmachini st.com%2Fvb%2Fdeckel-maho-aciera-abene-mills%2Fdeckel-fp3l-questions-392467%2F%23post3780428&v=1&out=https%3A%2F%2Fwww. anrdoezrs.net%2Flinks%2F100203028%2Ftype%2Fam%2Fsi d%2FPM-Forum%2Fhttps%3A%2F%2Fwww.ebay.de%2Fitm%2F33314108 9035&ref=https%3A%2F%2Fwww.practicalmachinist.com% 2Fvb%2Fdeckel-maho-aciera-abene-mills%2F&title=Deckel%20FP3L%20questions&txt=Gegen lager%20fur%20Gegenhalter%20%20Deckel%20FP3%20Univ ersalfrasmaschine%20RHV7766%20%20%7C%20eBay", which redirects with 302 some five times(!!!) ending up at "http://www.qksrv.net/media/offers/?AID=11873549&PID=100203028&SID=PM-Forum", which tells me "OOPS! Your offer could not be found...".
    I also see that the original posting just has ebay.de links. Looks like a misconfiguration, malware or else some kind of money grab by the forum software producer or owner .
  18. #14
    GERMANY
    3,677
    2465
    1486
    Jessica, who is one of the PM maintainers, wrote back to me that they have fixed the links above. I can not verify this, because they always worked correctly for me, and they did not tell me what what was wrong or how they fixed it.
  19. #15
    Sep 2008
    Canada
    1,696
    659
    662
    All three links now work for me.
    L7
  20. Likes ballen liked this post
