The machine has had 2 faults on the X axis where it says it lost the X reference point. Today it did it again, however when I home the X axis it goes to the emergency limit. I reset that using the Service window with the DIALOG password and move it away, however it does not correct the issue.
I had a CYCLOMETRIC SYSTEM DEFECTIVE: X error once. Following advice, I cleaned the glass scales using glasses cleaner and laboratory cloths on a zip tie inside the glass scales. There was some dirt that came out.
I have since tried to X home to which it goes to the limit. Resetting the PLC does not produce the Cylometric error, but it still goes to the emergency limit.
Where is the limit? Is that dirty? Is there a way to clean it?
I may be forced to remove the X glass scale and fully pull it apart to clean, however I will need to cut the frame to remove it. The FP50CC/T is 1.8m or so in length, so it may be quite hard to remove and clean it.
Any suggestions or help?
