Deckel GK21 remove spindle from roll attachment
TXNinAZ
Feb 23, 2017
Hi all- I'm a new GK21 owner and I'm trying to get my machine set up. I can't tell how I'm supposed to remove the spindle from the roll engraving attachment. It was in position when I bought the machine, and it appears that the pulley has to come off to free it, but I don't want to start cranking on things and break something expensive. I don't see in the manual anywhere how to set up the roll engraver, so that's no help (it came with the newer, boxier style manual while my machine is the older version). Any help?
The spindle should drop out of the upper housing and leave the housing above the roll attachment.
The manual has several pages on spindle removal and cutaways.
In short you remove the top knurled cap and then grip the lowest knurled ring on the spindle and push up and it should twist a few degrees and then drop out. Easier said than done but there is a small set screw inside that runs in a slot.
