Deckel LK LKS LKD
Page 1 of 2 12 LastLast
Results 1 to 20 of 25
    Dec 2019
    SLOVENIA
    28
    12
    Default Deckel LK LKS LKD
    Hi
    I just got myself a Deckel model LK, known as jig borer. I need to overhaul it a bit because it was sitting for a while and was not in use for some time. I. Was searching for a manual but couldn't find any. Do we have someone here that is willing to send it to me as PDF via email?
    Dec 2019
    SLOVENIA
    28
    12
    Dec 2019
    SLOVENIA
    28
    12
    I also couldn't get it to lower the head down by hand (wheel on the back right), like it's stuck. Is it possible to move Z axis without powering the machine on?
    Aug 2002
    France
    1,728
    330
    787
    I can't recall of any thread discussing LK machines on this board or anywhere else. Ever.
    When I say discussing, I mean by someone actually owning and using such a machine !
    Thinking about it,
    Good luck !
  5. Likes Laurentian liked this post
    Dec 2019
    SLOVENIA
    28
    12
    I think it would be great if we have a thread like this. This machine would deserve the thread, don't you think
    Sep 2008
    Canada
    1,541
    598
    596
    Well, I’ll be darned! I own a cool old Deckel that Tien doesn’t. Yet ;-)
    Yes, the Z axis, and the other axis as well, work without power. Just slower.
    I don’t have a manual or parts book for the LK either and would be interested in a copy as well.
    L7
    Mar 2001
    Switzerland
    2,715
    3041
    1270
    Does it have the electrical box?
  9. #8
    Dec 2019
    SLOVENIA
    28
    12
    Quote Originally Posted by Screwmachine View Post
    Yes it has two of them...and also it came with vacuum cleaner but sadly doesn't have a lid. Maybe originally they don't have a lid?
  10. #9
    Dec 2002
    Benicia California USA
    8,735
    2268
    3127
    For a short while i owned the conversion table that made a standard FP2 or FP3 into an LK...What i mean is Deckel built the same table that you have on your LK except it was made with a mounting
    face that bolted to the vertical table of the manual mills.(not FP1)
    Table had the optical scales and moved independent of the mill's slides....came with a frame work that carried the table with wheels allowing it to be rolled right up to the mill for mounting....
    Don't know much about the table , did not keep it long....
    Never seen any documentation on the LK's ...
    Be careful with the vertical head....Fits between the quill and the head casting are very close. Dirt and rust will be a problem there....There are two versions of head, A boring/drilling head, and a grinding head. Both were used with that machine.
    The quill is lubricated through a screw on top of depth stop rod (the bar on the front of the vertical head that has a small flat shelf on top) Move the bar (thumb screw) fully down.9after you clean off the rust) Remove the screw from the top of the flat shelf and apply oil into the hole....I would start with some light nachine oil to get things loosened up....
    The two cabinets contain the electrics for the machine(1) and the high frequency power source for the grinding spindle. Believe there are two versions of the high frequency supply, but i don't know more than that other
    than the first gen high frequency source is deemed troublesome....
    You do know that the ways on that table will make it useless for all but very light milling....Not designed to take side loads, just down thrust from drilling and boring...
    Cheers Ross
  11. Likes Laurentian liked this post
  12. #10
    Mar 2008
    Canada
    1,149
    6842
    211
    We bought a similar LK a decade ago for 1400 to nab the boring and drilling head, thinking we'd have use for it on our FP2. It sits there still in our cabinet's lower shelve unused.. Our shop neighbour kept some weird parts off it for possible use later as he's a millwright. Balance was carted off to metal recycling..
  13. #11
    Dec 2019
    SLOVENIA
    28
    12
    Alfa GTA I followed your advice also had to tap it on the lever to start to move the quill. It took me half a day to get it moving...back in my head I had this felling that i'm doing it wrong and will do some damage, but luckily this time it was a right way to loosen the quill. Thanks a bunch
  14. Likes Laurentian liked this post
  15. #12
    Dec 2019
    SLOVENIA
    28
    12
    Do we have anybody here that would know for what is this used for and most of all what it is....I was thinking that it's edge finder but I a bit sceptical...img_20200605_172108.jpg
  16. #13
    Aug 2002
    France
    1,728
    330
    787
    It's an early Centricator, forerunner of the Centricators CIII, also known as the Flying-centri-saucer....😋
    Very convenient to center the spindle axis on bores or buttons, and even on a part's edges with the suitable accessory.
    Also very fragile !
  17. #14
    Dec 2019
    SLOVENIA
    28
    12
    TNB thanks for the info...found also somewhere in the closet hidden some instructions of this Centricator and I already used it for tramming my bed on the mill. Very usefull tool ��. Now I have another question...found this two odd parallels or something. What could this be...a sinbar?img_20200613_223225.jpg
  18. #15
    Feb 2005
    Vancouver B.C.
    862
    17
    140
    I have scans of an LK operator manual in German and the multilingual parts manual.
    PM me with an email and I'll send you a copy.
    Chris
  19. #16
    Dec 2019
    SLOVENIA
    28
    12
    Quote Originally Posted by Chris999 View Post
    Chris
    Hi Chris, thank you....PM sent
  20. #17
    Dec 2019
    SLOVENIA
    28
    12
    Hi
    Can someone help me...I'm trying to repack and clean grinding, heads from Deckel LK. Did maybe someone dissembled them and repacked them successfully? I'm having troubles to dissemble the bearing on the tip of the head...everything else and upper bearing I could get out with some tinkering around. Also in case if Isoflex Super TEL grease is not available anymore, could I use Isoflex NBU 15. Thanks for your help guys or girls
  21. #18
    GERMANY
    3,565
    2337
    1417
    Quote Originally Posted by fastrider View Post
    Also in case if Isoflex Super TEL grease is not available anymore, could I use Isoflex NBU 15?
    Yes, you can use Isoflex NBU 15, it's what the professionals (Franz Singer, for example) use on these bearings.
  22. #19
    Dec 2002
    8,735
    2268
    3127
    Quote Originally Posted by ballen View Post
    Its not clear which "grinding head" the OP is referring to....If its the high speed spindle unit, don't think the NBU 15 is what one should use.
    Gotta be careful here as the terms can get a bit fuzzy.
    Cheers Ross
  23. #20
    GERMANY
    3,565
    2337
    1417
    Quote Originally Posted by AlfaGTA View Post
    Good point. NBU-15 is rated for D n < 1,600,000 where D is the bearing diameter in mm and n is the maximum rotation rate per minute. So for example if the bearing balls are on a 50mm diameter and the rotation rate is 30,000 rpm, one has D n = 1,500,000, which is still within range. But if the speed is a lot faster than that, a different grease may be needed.
