Yes, its that old question again !
I've been away from the forum for some time, but recently drip-feeding (or the lack of) has now become an issue for me.
I have searched all the old posts and found pieces of good information in various places, some dating back 3 years. Therefore I would like to get this topic up to date and at least have a solution that will work. Please put forward all successful ideas but try to hold back on 'ideas' that haven't been proven.
It appears Ross is the only one to have any success with this ? We have our own 3d cad/cam software (not SurfCAM) which we can use and do use, but the problem is with the very special file handling software used for this very unique DNC system. Our own RS232 comms software works fine with simple files that will fit into the 256k memory space. Please see my notes below and add anything that will help.
Please note this is for 'Drip-Feeding' NOT regular RS232 file transfer
Dialog 4 related answers please NOT Dialog 3 or 11 (Completely different)
To 'Drip Feed' large files (larger than 256k) with Dialog 4:
1 - Dialog 4 requires the NEP52 hardware PCB
2 - Deckel file handling software required to separate the large file into smaller 'packets'
and manage the required data to the Dialog controller.
What options are available for this software ? Is the original DOS version the only software for this purpose, or are there other version available ? Where can I obtain this software ?
3 - Is the cable for the 'special' software the same cable used for the regular comms type software ?
If not, what are the pin outs (D25 - D25) ?
4 - Are there any special settings required at the Dialog CNC control for this to work ?
5 - I'm told that the protocol used for drip feed is LSV2. Is this the very same as for Heidenhain ?
If so, can we use the old DOS TNC transfer software by Heidenhain ?
I have learnt via the service engineer that our FP4 machine certainly performed drip-feeding with its former owners around twelve years ago. The machine sat in storage in a warehouse for several years before I found it coved under rubbish next to its sister machine ! The sad thing is, that the FP4 became separated from its PC companion with the appropriate software. The service engineer tells me that this company had two FP4's and purchased the DNC kits for each machine along with NC500 tables and three-spindle heads etc . Sadly all gone never to be found again !
HELP !!??
Nick.....
HELP !!??
Nick.....
