DMG DMU 50 Evolution machine constants
Results 1 to 11 of 11
    Jul 2017
    GREECE
    17
    Default DMG DMU 50 Evolution machine constants
    Hello everybody, my name is John and I live in Greece. I have recently purchased a DMG DMU 50 Evolution 2000 built. It is in good mechanical shape and very little used. When I power it up it only showing 3 axis and not the 4 and 5 axis. I believe this is do to machine constants have been wiped out and the controller has now the defaults constants.
    I am trying to enter the menu to edit the constants but the controller wont do anything when I press F8 (menu) or Alt. Also the arrows wont work either. I know the keys are working because when I press them it goes out of the black and white screen saver, the controller just ignores them.
    I have printed copy of the constants and backup hard disc of Millplus but I don't know where is the plc program, is it in the hard disc or in some chip in the controller. Should I replace the battery insight the controller or I may loose something very important?
    Also I can make a copy of hdd or constants ans sent it to anyone need it.
    Oct 2006
    Petaluma CA 94952
    581
    96
    I have the same machine from 99-2000. If you're loosing constants, you'll need to replace the BR2335 battery in the EPC8 main board. It happens gradually as the battery loses a charge. Leave the machine powered up to charge the super capacitor fully. Then power off, pull the EPC8 board and change the battery, you'll have to move the ram simm out of the way to install the new battery. Did you flip the middle switch in the rear of the cabinet? You'll need to do that to write to the constants.
    I would just punch in the parameters by hand and see if that gets it going. You'll need to restart a few times as entering some of the constants unlocks other constants that you won't be able to enter on the first round. You have a set of manuals, correct?
    Jul 2017
    GREECE
    17
    Thank you for your help, I haven't noticed any switch inside the cabinet except the button that shorts the limit switches. I have some pictures from the insight of cabinet
    20200930_104248.jpg20200930_104254.jpg20200930_104302.jpg20200930_104323.jpg20200930_104410.jpg
    Jul 2017
    GREECE
    17
    Cabinet schematic.
    Is this switch responsible for me not be able to open any menu in the screen?
    Jul 2017
    GREECE
    17
    I have electrical drawings, millplus manual, machine manual, and some manuals from components of the machine, and the machine constants explanation in german.
    Jul 2017
    GREECE
    17
    Solved, to modify the parameters there is not a physical switch but a code entered in the controller.
    Once you are in the parameters you have to enter 1234 and hit enter. Then the parameters can be edited
    John
    Oct 2006
    Petaluma CA 94952
    581
    96
    Did you get it going? You have a newer version of the mill plus control. There is the next version from mine which is vme based and has an Epc8a motherboard and then there’s the version that runs on a pc thats not vme, dont remember what that hardware is but has the backup battery in a different location.
    Jul 2017
    GREECE
    17
    The PC is like this
    I have change the position of the cards in the pc and it seems to working, I don't know for how long
    John
    Jul 2017
    GREECE
    17
    I will try to put new capacitors to the motherboard, I thing this is the reason it is not working correctly. I have ordered a new pc Philips PG1220 just in case something gone wrong in recaping the original pc.
    Jul 2017
    GREECE
    17
    Hi to all, as you can see in the video the position of the tool change is off by two to three millimeters, I have noted the machine position coordinates during the tool change in order to find them in machine constants and correct them but I cant find them. Any one knows the procedure and the MC I must change to align the spindle correctly for the tool change?
    John
  11. #11
    Jul 2017
    GREECE
    17
    Solved, Millplus has the machine coordinate system with the zero to the index of the glass scale close to the limit switches. This coordinate system it is not the g53, the g53 is offset to this with the value in machine constant 3114 for the x axis (mine 3114 is 500600), so the operator sees positive numbers for the travel of x axis, 0 at the left end of travel and 500,000 at the right end for the x axis. The machine constant for the position in x axis above the tool in the right chain is 3148 and for the left chain is 3160. to change the two constants I had to change the negative limit travel constant 3119. to align perfect with the tool changer I will make something like this in the post
    Contest for the most insane member (They will be a Maho owner)
    288874d1589751481-contest-most-insane-member-they-will-maho-owner-20200517_110640.jpg
    I hop this will help others with similar problems
    John
  12. Likes dominus164 liked this post
