Dolly for supporting angular table
Likes Likes:  0
Results 1 to 8 of 8
    Nov 2011
    Alberta
    480
    50
    118
    Default Dolly for supporting angular table
    Has any one built a dolly for wheeling around the angular table on the FPNC's? Specifically one that will hold it in a position which would facilitate mounting to the machine with out the need for a crane.
    Oct 2004
    UNITED KINGDOM
    1,402
    85
    529
    Quote Originally Posted by legoboy View Post
    Don't know about Deckel table dollies, but I think Thiel had one for their mills. As I recall it was a tubular steel design with casters. I have never seen one in real life, so probably rare.
    Oct 2005
    Pittsburgh, PA
    1,693
    135
    Hi
    There is a photo of a dolly in this recent thread.
    Storing Heads?
    I used a lifter / stacker by Presto (or maybe another one) the few times I have removed the table on the FP3NC. I only have the one table so it usually stays on. I can't use the forklift in the mills location unfortunately.
    Andy
    Oct 2005
    Pittsburgh, PA
    1,693
    135
    In this thread DennisCA did a nice job of modifying an engine lift to lift his mill. That might work well for the tables, heads and other attachments.
    Deckel FP2 acquired (Preliminary)
    Andy
    Aug 2006
    New Zealand
    1,239
    72
    247
    Quote Originally Posted by Andy St View Post
    Hi
    Storing Heads?
    Andy
    Hi
    I brought that with the mill. It works well for the tables. I want to modify it to carry/fit the heads.
    I have a transmission lifter but it is unwieldy to move around the workshop.
    Dazz
    Dec 2002
    Benicia California USA
    8,022
    1793
    2372
    Pretty much every shop has space issues...busy work areas tend to get congested. Floor space becomes the most expensive commodity in the shop.
    The area of most flexibility and available space would be the overhead...While i realize that having overhead lifting might present challenges of both construction and cost it is the
    area that will not interfere with the machines or work....
    Spend the time effort and a bit more expense (perhaps) and gain valuable space....Its sort of two features in one solution....You get the move heavy parts/accessories without further
    congesting your work space with floor mounted solutions....
    Cheers ross
    Jul 2010
    eugene,or
    844
    85
    351
    I use a hydraulic lift table with a few blocks to hold the table in position. I had to modify the wheels to bridge the base of the mill but it works ok. It takes up floor space but is useful for other tasks as well.
    Teryk
    Sent from my XT1710-02 using Tapatalk
    Nov 2011
    Alberta
    480
    50
    118
    If one uses a lift table as mTeryk does could you wrap a sling around the the Y axis slide then bolt an eye on the table then use the Y axis to support the weight. Then you could jog the Y out far enough to get past the base? How much weight do you think the Y axis could support? Just throwing ideas out there....
