First Time CnC, Contour 3 help needed! - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 75 of 75
  1. #61
    Feb 2001
    Redwood City, CA USA
    5,176
    216
    1046
    It sounds like it's doing what you told it to do. The Z-5.1 move in G75 is measured from the prior position, Z5.0. So the machine is at Z5.0, wants to move down an increment to -5.1, which would put it at Z-0.1, except you told it to leave a 0.05 finishing allowance on Z, hence you end up a Z-0.05 instead of Z-0.1.
  2. #62
    Jul 2020
    MALTA
    9
    Thanks for your reply as I'm new to CNC I never had the chance to use a CNC at work so I always used a conventional milling m/c.
    Another thing I'm getting E1 error on the z axis. But every thing seams to work well. I checked the book and I couldn't find nothing about E1 .
    Regards Loren
  3. #63
    Nov 2004
    SLC, UT
    754
    1043
    176
    Post a photo of what the screen looks like when you get the E1 error on the Z axis.
  4. #64
    Dec 2002
    Benicia California USA
    8,547
    2115
    2937
    Thing about Deckel canned cycles is that all depth moves are done using incremental values, even if your are running the overall program absolute.
    So any "Z" (or Y) moves will "Move" the tool the amount programmed...its the tool move, not the actual location.
    Cheers Ross
  5. Likes Colt45 liked this post
  6. #65
    Feb 2001
    5,176
    216
    1046
    I get a plain E error if I run an axis travel to its end, but not an E1.
  7. Likes AlfaGTA liked this post
  8. #66
    Jul 2020
    MALTA
    9
    Here is a photo of my error. I get E as well while I'm on the limit.
    Internet - Google Photos
  9. #67
    Nov 2004
    SLC, UT
    754
    1043
    176
    Dialog4 machines here so there may be some differences compared to Contour- never seen that exact error but my guess is it's either you are at the end of travel for that axis like rklopp mentioned or that you have a dirty scale on the Z axis.
  10. #68
    Nov 2016
    FINLAND
    315
    35
    35
    My contour 3 control is now in the past. I upgraded to LNC M-516 and use old servos and and servo amps.
    Yesterday was able to move all axes and turn spindle, all gear changes also work really nice
  11. Likes zephyrous, Mud, AlfaGTA, mTeryk, Colt45 liked this post
  12. #69
    Oct 2012
    Austria
    177
    16
    47
    Can you post some info and pictures of this interesting retrofit?
  13. Likes mTeryk liked this post
  14. #70
    Dec 2002
    8,547
    2115
    2937
    Plus 1 on more about your retro...Perhaps start a new thread with details and lots of photos....
    Cheers Ross
  15. Likes zephyrous, mTeryk, Colt45 liked this post
  16. #71
    Nov 2016
    FINLAND
    315
    35
    35
    I will try to Make a thread at some point. Need some tweaking with parameters and reference zero point etc.
    I tried some circular Canned cycle yesterday and oh boy, that was smoooooth running compared to old control No stops and jerks.
    I did the wiring from diagrams and figure out deckel I/O cable numbers.
    I had zero experience of this stuff before.
    All credit goes to Johannes Thelen from Thelen tech.
    He did all the wiring diagrams, parameters, all coding for gear change etc.
    His support has been excellent and priceless
  17. #72
    Jul 2010
    corvallis,or
    882
    95
    372
    I'm assuming that it is this company
    Thelen Tech - Automaation ammattilainen - Delta Electronics
    Teryk
  18. #73
    Nov 2016
    FINLAND
    315
    35
    35
    Yes, same company.
  19. #74
    GERMANY
    3,322
    2143
    1266
    Quote Originally Posted by Harri89 View Post
    I did the wiring from diagrams and figure out deckel I/O cable numbers. All credit goes to Johannes Thelen from Thelen tech. He did all the wiring diagrams, parameters, all coding for gear change etc.
    If you could share those diagrams and parameters with this group, I am sure it would be appreciated!
  20. #75
    Nov 2016
    FINLAND
    315
    35
    35
    No offense for you guys, but i have to ask permission from Johannes for this. I have huge respect for him, his help and effort.
  21. Likes ballen, AlfaGTA liked this post
