OK...hold on a sec...
I have both Dialog and Siemens controls.
Before you guys get along too far, it is important to address that Ross and Tom should be looking at conversions from two different places...
Here's why...
Tom, since you've never had a Grundig (dialog) controlled Deckel, you have to realize that symantics aside, you already have a "converted" machine.
The 3M is a Generic control...or I should say "universal".
Those Heidenhain converter boxes you have from your scale outputs can be considered "adapters"...the Dialog/Bosch proprietary system doesn't use them.
The conversion that Ross is speaking of is...in essence...converting to something similar to what you already have Tom...that is...cheaper parts...a little more capability...a little more mainstream.
Although his choice is a HH 310, he is pondering to get where you more or less already are.
Now, the Dialog control is a special control...working on it has some charms and Ross would like to get as close to that as possible...which the 3M isn't, but that is a matter of preference.
I also prefer the Dialog, but I purchased my 3M because it is already 75% "converted" and I figured I would change out the front end to a later model Siemens (810?).
Since the Siemens system is already "universal" and is programmed/adapted to each application, I figured it would not be a wild step to program a more modern front end to work seemlessly with the amps(etc) already installed by the factory with the 3M...especially since the critical factory parameters could be transferred directly.
I cannot see any reason why you would start replacing amps and the machine side of the control system away from what you have since it is old enough that used parts can be had, popular enough that used parts can be found, but new enough that it can already be programmed to tell the machine to do things that the machine cannot physically do...and new enough that it should still integrate with an even newer front end that has more bells and whistles.
Although I have not done it yet, I will have to guess that a direct Siemens/Siemens *upgrade* is the way to go and not a retrofit from scratch.
Anyway, that is why I have one.
Now, for the gear changes...
Ross, I am guessing about the proprietary board taking care of the gear changes and simply reporting "completed" to the control.
There is of course an upside and downside if this is true.
The upside is that obviously that board can interface with a "universal" control with no problem (since it's done on the 3M), and very little programming would be required.
The downside is that you have to keep a proprietary board with your retrofit...which could eventually fail and cost.
If this chore is done by the control itself being harwired into umpteen relays...well there's a bright side to that to...it would already have been done again on the 3M and would have a known set of parameters to copy/translate into whatever control you needed as well as a known wiring scheme.
Ok, so point is that the 3M is a conversion for all intensive purposes. There is nothing I can find that is proprietary about it and the Deckel...just programming and wiring. So it has been done and can be used as an upgrade platform for someone like myself or Tom, and as a model for someone like Ross.
Thoughts/Comments?
Sean
