FP1 Veritcal milling head lubrication
Results 1 to 20 of 20
    Aug 2014
    IRELAND
    19
    Default FP1 Veritcal milling head lubrication
    I have concerns about the lubrication of the vertical milling head , particularly the horizontal shaft gear which engages with the gear on the horizontal spindle.
    If I am reading documentation correctly, the gear is lubricated with oil carried from the main gearbox on the gear of the horizontal spindle and to the upper drive gear. The oil level is correct on my FP1, by sight glass on left side of machine, but I feel the gears are dry when I recently removed the vertical milling head. I did find two wicks either side of the horizontal spindle housing but one was loose so perhaps this should be going somewhere. Incidentally, the housing was wet with oil just the gears felt dry.
    Is my understanding of the lubrication mechanism correct and should I being checking or doing something to ensure better lubrication?
    ger
    GERMANY
    2,981
    1907
    1094
    Quote Originally Posted by gotoole View Post
    Had the machine been out of service for a long time? When the spindle is rotating, oil is carries up from the sump on all of the gears, so after a few seconds of operation the long horizontal top gear on the horizontal spindle will be wet with oil. But if the machine is sitting unused for a long period, that oil drains back down.
    If you want to confirm this, try running the machine with the vertical head removed, and no cover on top of the machine. Just keep the spindle speeds low : at high speed you will spray oil everywhere. And take care with your fingers around the exposed gearing!
  3. Likes Laurentian liked this post
    Aug 2014
    IRELAND
    19
    Thanks Ballen
    the machine hadn't been used for a few says, maybe even a few weeks.
    I will do as you say, at slow speed, and check that all is well
    Ger
    GERMANY
    2,981
    1907
    1094
    If the machine is new to you, I suggest changing the oil in the feed and speed gearboxes. This is easy and inexpensive. I think you need ISO 46 weight, but check the manual first to be sure.
  6. Likes Laurentian liked this post
  7. #5
    Aug 2014
    IRELAND
    19
    Thanks Ballen ,
    I do have ISO VG 46 oil .
    Am I correct that I drain the main gearbox from the bolt om of the sight glass and fill through the screw hole above it?
    Thanks for all your help
  8. #6
    GERMANY
    2,981
    1907
    1094
    I have an FP2 not an FP1. Do you have a manual for your machine? If not, you can download one for free from Resultats de la recherche pour la requete: deckel | Usinages
  9. Likes Laurentian liked this post
  10. #7
    Aug 2014
    IRELAND
    19
    Thanks Ballen
    I will try to join to download
    regards
    Gerard
  11. #8
    GERMANY
    2,981
    1907
    1094
    I think you need to sign up, but that's free. They have many pages of Deckel manuals, and several different FP1 versions. So if you search a bit you can probably find the manual for your exact generation -- the FP1 evolved quite a bit over the half-century that Deckel was manufacturing it. Most manuals there are available in English, German and French.
  12. #9
    Aug 2014
    IRELAND
    19
    Thanks Ballen
    I did manage to sign up , ( I have forgotten most of my school French) . And yes I have managed to download a few manuals for the FP1.
    I found a very useful manual which has a lot more detail than any manual I have found previously. It is in German but I will use Google translate, along with the little I know, to translate.
    Thanks very much.
    Incidentally, that little screw did allow me to drain the oil and I refilled with the correct ISO VG 46. Thanks for all your help.
  13. #10
    Oct 2004
    Denmark, Scandinavia, Europe
    755
    28
    70
    What age is your FP1? I scanned a 1938 manual.
    I can send you a Dropbox link, so you can download it.
    But maybe that's the one you found. I saw they took it - it would have been prudent to ask.
    I have never seen a sight glass like that on an FP1 - so it could be very old (?).
    Cheers
    Erik
  14. #11
    Oct 2006
    United Kingdom
    244
    45
    From memory, my oldish example has a sight glass on the side of the column. The vertical head gear would be wet with oil after running for a while.
  15. #12
    Aug 2014
    IRELAND
    19
    Quote Originally Posted by Erik View Post
    Cheers
    Erik
    Yes Erik, I would love to get a copy of the manual if you are happy to send it. The manual I done loaded is not a good photocopy as it has a lot of blacked out pages and dark areas where the text is hard to see and read. Should I send you my email address?
    I believe, from the previous owner, that it is quite old but I have no way of checking that to be sure. The sight glass does look correct but it also could have been added during it's long career. I will try to fond out more.
  16. #13
    Sep 2019
    CZECH REPUBLIC
    10
    5
    Cheers
    Erik
    If the manual is in English, I'd love a link too, I am also owner of a version of fp1 with secondary oil nipple
  17. #14
    Aug 2014
    IRELAND
    19
    Poyo
    I can send you the German manual I have, if that is any use to you.
    Gerard
  18. #15
    Sep 2019
    CZECH REPUBLIC
    10
    5
    Poyo
    Gerard
    I've found several PDF format German manuals, which is fine I can understand German fairly good but English would be much easier ofc, ones I have also are bad copies from black/white scans. If you have some better scans, would be appreciated.
  19. #16
    Feb 2017
    SWITZERLAND
    69
    12
    27
    Thanks Ballen ,
    Dear Gerard
    This sight glass on the left side of the column of your FP1 is typical for a FP1 Mk.1 (change wheel model for the auto power feeds, built from the mid 1930s until the late 1940s).
    Would be nice to see more photos of your machine.
    If you need any help with translations from German to English, let me know.
    Best, Stefan
  20. #17
    Feb 2017
    SWITZERLAND
    69
    12
    27
    Quote Originally Posted by poyo View Post
    Dear poyo
    This vertical head seems to be also (as Gerards) from a FP1 Mk.1.
    Point F is for pressing in grease, points K and S are for oil.
    Best, Stefan
  21. #18
    Aug 2014
    IRELAND
    19
    He Stefan
    Thanks for your help
    I will take some more photographs and post them. Is there any particular items or views that would be more useful?
    regards
  22. #19
    Sep 2019
    CZECH REPUBLIC
    10
    5
    Quote Originally Posted by quarkgluonplasma View Post
    Dear poyo
    Best, Stefan
    Hello Stefan,
    Tnx for the info, I believe I have the same manual in PDF format too. I haven't started to renovate my machine yet. I purchased it a little less than a year ago, just checked several times if it has any issue with moving parts but everything seemed perfect. I'll start hopefully late summer to tearing it apart and cleaning, painting etc. Btw in which part of Switzerland are you living? I work for a Swiss company Buhler, often travel to Uzwil
  23. #20
    Aug 2014
    IRELAND
    19
    Here is a picture taken when it was delivered. Not pictured is the horizontal milling anvil /arbor support which also came with the mill
  24. Likes Laurentian liked this post
