AlfaGTA
- Dec 13, 2002
- Benicia California USA
Been doing some overdue work on my FP2 Aktive machine and thought it might be of interest here.
It is my opinion and practice to clean and pack the spindle of any machine (Deckel) hat comes into my hands. Been pretty delinquent about doing this machine until now.
This is a late square head machine but the process ans general parts are pretty much the same on the earlier versions.
First thing is to remove the spindle/quill assembly form the vertical head.
While it might be possible to remove the spindle while the quill is fitted to the vertical head i do not think this a viable option as it would be impossible to get everything clean enough .
All manual "FP" quills come out in almost the same way.
The first requirement is removal of the draw bar.
Early machines use a flat thick threaded washer at the top end of the draw bar. It is secured from rotating with a taper pin through the washer and draw bar. Removal is simply to drift out the taper pin, and unscrew the washer while holding the draw bar. Once the washer is removed the bar will drop from the bottom of the spindle.
The reason the draw bar must come out is that the washer overhangs the drive slots in the spindle and will not allow it to slide out of the driving gear in the vertical head.
Being a later style machine it has a different retaining arrangement on the draw bar.
In this case the retention has three main parts in addition to the draw bar.
There is a snap ring nested inside the outer body.
Held i with the snap ring is a flanged circular part with the internal hex used to tighten the draw bar.
Pulling the top inner part up reveals the draw bar with its hex end, and two dowel pins that couple the top to the lower outer body (see holes in the floor of the outer body).
The outer body is threaded to the draw Bar and can be adjusted for backlash using the coupling dowels to the top part.
This system allows adjustment of the clearance between the spindle end and the top nut while providing a replaceable part where the wrench (allen key) is used to tighten the draw bar.
Removal of the draw bar is same as with earlier machines. Unscrew the washer (outer body) and the bar will drop out the lower end of the spindle.
Next thing required is to pull the hand feed shaft.
Both late and early machines are pretty much the same here.
Photo shows the wrench side of the shaft. Late versions have a hex socket to allow use of the Allen key to position the quill. Earlier machines have a square.
Shaft passes all the way trough the head casting. The side away from the operator has the return spring.
This view shows the spring housing already with the center retaining screw removed.
The housing is coupled to the cross shaft through a fine toothed spline.
Once the retaining screw is out the shaft can be pushed out of the head. The gear on he shaft that drives the quill is helical so it requires rotating as it is pulled from the head. I use a ling screw in place of the retaining screw to ease pushing the shaft out.
More to follow.................
Cheers Ross
Cheers Ross
