I have noticed that the plunger pump that sends oil to the spindle head isn't working. It may be the solenoid, relay or something else?
Does any one know which relay operates the pump so that I can manually test it?
Looks to me as there is no relay on that solenoid. (Y10) Connected directly to the PC on pin 6 of X51.
That would be an output directly off the first NEA 90 board.....
Has an indicator LED , should light when the power (24v) is supplied to the pump.
All this assuming that you have a Dialog4 control fitted with a PC2.....
If it is not working, suggest you swap the NEA90 boards.Be sure to verify that the fuses are good on that board.
That pump is very intermittent...Not sure it ever cycles if the spindle is not running.
Isn't there like a M-code or manual button for head lubrication on Dialog4 machines for testing that? Like press lube button and hear if some relay clicks in control box.
On Dialog11, there are 2 F-buttons in manual mode, to lubricate spindle and ways manually. You could hear some pumps working, when doing so.
There is a hard button (Dialog2,3&4) for way lube on the operators panel....
Not aware of any trigger or code for the vertical head lube pump.....Would love to learn that there is if it exists....
I was told (factory service tech) that on the "flip head" machines which have a clear lube line to the vertical head, that if that line were full of bubbles or empty, that the remedy
was to remove the cover for the shift motors and cycle the pump plunger by hand till the line was full and the bubbles gone....
Seems if there were some keystroke that could do this there would be no need to open up covers and manually pump the oil up....
Cheers Ross
