AlfaGTA
- Dec 13, 2002
- Benicia California USA
Need to finish grind the part shown below. Material is 8620 and the part is carburized and hardened to give a surface hardness of RC 55-60. Because of the shape and size of the part (Deckel gearbox part by the way) i opted to finish grind...not enough to hold on to to hard turn.
Base shaft was turned and the eccentric pin milled on the NC using circular interpolation before going to be hardened.
Here is the basic setup:
Part held in a 5c collet in the index spacer....not using any indexing here , just the collet and lever action draw bar to hold the part in one position.
I am using the a UPA3 "Wally" boring head. The grinding umit is an NSK "Planet 500" air powered jig grinding turbine. I don't have an "LK" so this is my solution. The NSK setup is pretty slick. Comes in a wooden box that carries the air regulator and lubricator. The gadget off to the side is a 2-4-6 block clamped to the table to provide a stable base and height for the dressing unit. This is also an NSK item. Has a micrometer dial that moves the diamond in and out so you cam control the amount dressed.
This is a critical element n any grinding operation but very important here where the power of the grinder is limited. Need the stone to freely cut and that takes a fair bit of dressing to keep it sharp.
Here the setup has been changed to allow grinding on the short eccentric nub of the part....more or less the same as doing the longer section. It is also important here to provide a relief at the intersection of the shaft and the "web" so as to allow grinding off the part and getting a good square corner......
Note the paper to keep flying grit off the machine ways.
Close up of the short section.....
The stripes showing in the close up are marks made by the lube oil from the turbine getting on to the part surface....they wipe off.
Lower edge of the stone in close photo shown to be a bit rough...i used a "norbide" stick to dress the face with a center relief so i could also grind the face of the web of the part....I
believe that is the reason the edge looks a bit rough...works fine.
Cheers Ross
Cheers Ross
