Fritz Werner FV0 Vertical Mill info or manual wanted
Likes Likes:  0
Results 1 to 4 of 4
    Jan 2013
    Notts, UK
    Default Fritz Werner FV0 Vertical Mill info or manual wanted
    As a newbie i am not sure if i posted this the correct thread but as its a German made small vertical mill seemed about right
    I have just bought a Fritz Werner FV0 vertical mill which i cant find out any info, If any one has one of these and or a manual please contact me, i can email a picture i was going to add one but not sure how
    Mar 2007
    Norwich U.K. & Marvao, Portugal
    389
    934
    179
    racingrotax,
    Take a look on this site: Lathes
    You'll need to look around a bit & Fritz Werners are listed under Werner, see below.
    Ray
    MW350 WERNER (Fritz Werner) 3.230 Vertical Milling Machine. Operating and Maintenance Manual including large electrical schematics. £110
    MW350A WERNER (Fritz Werner) 3.275 Spine Shaft Grinder. Operating Manual with Wiring Diagram. £85
    MW350E WERNER (Fritz Werner) 4.221 Double-spindle Milling Machine. Operating and Maintenance Manual. £65
    MW350G WERNER (Fritz Werner) 5.131 Vertical Milling Machine. Operating and Maintenance Manual including large electrical schematics. £110
    MW350K WERNER (Fritz Werner) 9.101 Horizontal Milling Machine. Operating and Maintenance Manual including large electrical schematics. £110
    Mar 2014
    United Kingdom
    27
    Hi Racingrotax, I wondered how your search for a manual went. I have a FU0 , the universal version of yours , and would very much like to get a manual for mine, but failing that I would be very grateful for a copy of yours if you could help - the table feeds etc would be the same and probably the main drive mechanics...
    Dec 2002
    Benicia California USA
    8,175
    1861
    2507
    OP has only one post and that was 6 years back...Does not seem too active here.
    Cheers Ross
