Heidenhain ND960 DRO.... which parameter to tweak to get X axis reading accurate ?
Results 1 to 6 of 6
    Dec 2000
    Coastal Dogpatch, SC, USA
    50,816
    2472
    5332
    Default Heidenhain ND960 DRO.... which parameter to tweak to get X axis reading accurate ?
    This on the Fehlmann P50.... the scales are hidden away within the table so I can't see which scale models it has....but the signal period is currently set at 40um.
    The issue is, if I move X to get 1.0000" travel on the DRO, the actual movement is about 1.20". So, seeing as the signal period choices at 10, 20, 40, 100 um seems like changing to one of those would result in more drastic differences. Thoughts ?
    Sep 2002
    gloucester ma
    1,844
    70
    1334
    1.270 perhaps?
    1000 line per inch scale.......
    Dec 2002
    Benicia California USA
    7,503
    1554
    1814
    Is there a scaling factor wound into the "X' Display?
    Cheers Ross
    Sep 2002
    gloucester ma
    1,844
    70
    1334
    I remembered the 1270[well, close enough to look it up] because I once hooked an ooooooooooooooold US scale to a reader head, and it would read correctly in single thousandths[no half] in metric mode
    Feb 2003
    Athens GA USA
    139
    6
    7
    Some ideas to mess with:
    a. P1 (inch or metric)
    b. P11 Activate scaling factor
    c. P12.1 to 12.3 Scaling factor (factory setting is 1.000000
    d. P31.1 to 31.3 Signal period of encoder
    e. P32.1 to 32.3 Subdivision of encoder signal
  6. Likes AlfaGTA liked this post
    Dec 2000
    50,816
    2472
    5332
    Quote Originally Posted by AlfaGTA View Post
    Cheers Ross
    Scaling factor parameter P11 was "off" so,turned it on and that fixed it sure enough...thanks folks
  8. Likes rklopp liked this post
