Peter from Holland
- Jan 15, 2005
- The Netherlands
For my future reference, what components went bad in the Heidenhain power supplies you fixed ? Often in CNC related power supplies it is weak or bad electrolytic capacitors...I've not yet encountered a bad Heidenhain DRO ps problem...but eventually I probably will.Hi Peter,
So far I have fixed 3 HH displays. In all of them, the problem was the power supply. Normally such problems would affect all three axes, but if the power supply is starting to fail, it might first affect one channel. So in your place I would open it up and check the different voltage rails. You want to make sure they have the correct DC values, and noise and ripple values measured in the tens of millivolts. If you have an oscilliscope and voltmeter, this should not take more than a few minutes.
This style ? Interesting....don't think I've ever found one of those bad...good to know they can be a suspect. Re caps, I have an ESR meter as well....wonderful device for finding suspect caps without removing from board, then remove to confirm.In two older VRZ models it was burned out 3-pin TO3 voltage regulators.
This style?
Hi Peter,
Cheers,
Bruce
Do you have the expected voltages from the transformer to the board for a HH VRZ750?
Notice
