I'd like to hear how you remove your deckel 40 to 20 mm tapered sleeve reducer ?
There is a flat on it to grab with a wrench, but of course no draw nut like a 4 morse to 20 mm reducer has.
If you have to knock out the tapered pin that holds the draw bar in each time you need to remove the sleeve, it would be quite an inconvenience....
Markus
Markus
