Long reach boring,FP4NC - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 32 of 32
  1. #21
    Dec 2002
    Benicia California USA
    8,747
    2285
    3132
    Thanos:
    The setup went like this....
    First setup the case as far from the machine column as practical.
    Align the case using the crank as the reference , making the axis of the crank dead parallel with the
    horizontal spindle.
    Indicate to the center of the crank using short tooling.
    Move the position of the spindle to reflect the factory center to center distance from the crank....Average the vertical height using the opposite fan shaft bores and the crank bore to
    project the height of the counter shaft bore...the side to side location as stated is taken from a factory drawings (lucky to have this)
    Use short tooling to true up the rear housing bore, face the register surfaces both inside and out for the flanges of the bearing carrier. Set control registers to zero....
    Remove short tooling, fit long bar. Indicate as shown using the just finished bore as a datum.
    Note difference in position from first dial up and bore with short tooling.
    Calculate droop of bar using the change in position to indicate true, proportion for the additional length of the bar, move to make that correction and set the registers to zero.
    Bore inner housings.....Have beer....
    Cheers Ross
  2. Likes JHOLLAND1, Kjelle, Peter S liked this post
  3. #22
    May 2002
    South Central PA
    14,591
    2829
    4327
    Do you do anything to compensate for the indicator possibly reading differently right side up vs upside down?
  4. #23
    Dec 2002
    8,747
    2285
    3132
    In this case i don't...use the same indicator (Interapid) so i believe the error is balanced between the short and long setup.
    Have the same issues with the line boring machine setting the bar....The interapid indicators are pretty good on the gravity change aspect...
    Cheers Ross
  5. Likes Mud liked this post
  6. #24
    Mar 2015
    GREECE
    729
    263
    195
    Quote Originally Posted by AlfaGTA View Post
    .... Indicate as shown using the just finished bore as a datum.
    Many thanks for that! Will try to keep it in mind!
    BR,
    Thanos
  7. #25
    Dec 2014
    ESTONIA
    79
    34
    14
    How precise is spindle axis movement ? I mean if you put test mandrel to collet, dial indicator on table and move axis in and out.
  8. #26
    Jul 2002
    3,386
    20
    68
    I always have loved your posts, Ross... So much to learn there!
    I have to say that you have nerves of steel though. I think I'd be having a heart attack on each and every one of those revolutions to cut... Let's see.... 60 heart attacks a minute (60RPM) times whatever.... I'm pretty sure I'd be dead.
    I'm kind of stunned that it all worked out so well, especially since you had to shorten the bar at some point, I assume. but doing this would change the sag. which would require a change in the cutter offset or you'd have a different diameter. It must have been a pain to get that perfect.... Or maybe I'm missing something.
    Alan
  9. #27
    Dec 2002
    8,747
    2285
    3132
    Posted this some time back. Thought some might be interested in the short update.
    Entire lower end was finished for all machine work. Bearings fitted and all clearances checked.
    Rods assembled with new OS bearings (made for this job) all clearances checked.
    Crank assembled and end thrust set. Crank checked for freedom of rotation...
    Job sent to Porsche America (LA) for final assembly and run in...
    Finished engine on Dyno ready for test running...awaiting performance reports.
    Cheers Ross
  10. Likes jz79, Matt_Maguire, ballen, Colt45, Mud and 7 others liked this post
  11. #28
    Sep 2002
    Salinas, CA USA
    4,707
    483
    393
    Ross, did you end up using the autocollimator for any portion of the alignment?
  12. #29
    Dec 2002
    8,747
    2285
    3132
    Dave:
    No I did not use any optical alignment . Stuck with things i felt more comfortable with.
    Did all alignments mechanically. Test bars, indicators plus purpose built fixturing....
    An autocollimator would have been a good way to get things true, but i did not feel good about devising a good method to employ the instrument.
    Actually did the alignment for the main boring three times....First go,the derived location of the boring bar relative to the front main housing bore was far enough different it made me suspect my approach.
    Changed my method and did the setup again with similar results...Did it a third way and when the results repeated i figured that i had it properly aligned....Just wanted to be sure.
    Cheers Ross
  13. Likes Charles P, rimcanyon liked this post
  14. #30
    Nov 2004
    SLC, UT
    805
    1143
    215
    "Trust, but verify"...
    Thanks for sharing this with us.
  15. #31
    Oct 2005
    western washington state
    3,806
    2870
    4086
    Default jack screws
    Ross
    any chance you would know maker of leveling screws in Porsche dyno cell?
  16. #32
    Dec 2002
    8,747
    2285
    3132
    Sorry ,no clue, but i would wager that they are German.....
    Cheers Ross
  17. Likes JHOLLAND1 liked this post
