rimcanyon
- Sep 28, 2002
- Salinas, CA USA
I add an M08 after every tool change, since the tool change shuts off coolant flow. However, by the time the coolant flow is full, the cutter has cut ½” or so. Is there any way to add a dwell? I suppose I could convert the G00 after the tool change to a G01 to slow it down, but I’m looking for a better solution than messing with feed rates. Maybe add a check valve at the pump outlet?
