Epicycloid
- Oct 17, 2004
- Shady Cove, OR
I am getting a Maho MH400 P, that I want to use as a manual mill, or I as I have been saying, in "electro-manual" mode, since I want to enable the electrical stuff to allow the hydraulic tool change and clamping of the feed axis movements.
I just posted my hydraulic questions in a separate thread. Assuming I get the hydraulics working which, via some means I don't understand yet, I think just "clamps" the various axis screws, I will eventually have feeds on X, Y and Z, and maybe even quill feed.
But those are all driven by one servo motor.
Attached is a pic of the mess at the back of the column. The servo motor is the grey lump in the middle of the tangle of wires. I didn't get a close up of it. In other posts I've read that Maho used DC brushed motors, with an encoder or resolver of some sort.
I did get a nameplate photo, which with Google Translate tells me it is a "servo motor ??? direct current". The nameplate has two 85-ish volt ratings, at 14.4 and 22.2 amps.
Can I buy a DC drive (like something from AutomationDirect), rated appropriate for the motor (22+ amps?), and use that as a speed control, to just use the original motor as a variable speed drive motor for the axes?
Or is there more to it?
Or is there a more modern, drop-in replacement path I might be better going down?
Thanks for any help or hints,
--Jon
(My other hydraulic post hasn't appeared yet... pending approval I guess.)
--Jon
