AlfaGTA
- Dec 13, 2002
- Benicia California USA
So the title is a bit vague, but i will try to clarify.,
I do a bit of running from time to time with a driven accessories (slotting head, precision boring head, and riser) mounted on my 1st gen ("Camel back") FP4NC.
Now i do own the factory blanking off shield that is used when running horizontal...no problem and it works fine...Slips into the dovetails and seals top the
end of the "Y" slide and to the front of the vertical head support casting (nests below the vertical head) when all is drawn back to give the horizontal clearance....
My question is does anyone know of a factory accessory that is intended to fit to the rear of an installed driven accessory like the slotting head....
When the vertical support is moved rear to give mounting space for the accessory, there exists some open space between the driven accessory and the vertical head assembly.
If you look at mu post (#3) in " Making a riser for the FP2" you can see my solution just to the rear of the riser...Simply a piece of sheet aluminum that is cut to fill the space..
I have bent one edge down to give a sort of stop to locate the material...
I am just wondering if Deckel ever addressed this issue and if so has anyone ever seen their solution?
Cheers Ross
Cheers Ross
