Besides the hydraulic draw bar issue, suspect the dovetail is wider on the FP2NC ram, right ? Plus it would look rather strange....
I guess what I'm saying Don is that the FP2NC head isn't meant to be removed/swapped and as far as I remember isn't driven by the same gear as the provided for "attachment" heads, therefor no interchangeability is designed into it AFAIK.
I could be wrong... been awhile.
Not to jack this thread but I'm going to take my fp2 riser block and precision boring head over to a friend's and try it out on his FP2NC. Sounds like we won't have to remove his head, just slide it back and put the riser on from the front.
Is that the case? It will simplify matters if it is.
Teryk
One further note...as to accessories,believe the FP2NC only can use the FP1 accessories (14 1/2* pa. gearing) Furthers my argument that the equivalent CNC machine to the FP1 was the FP2NC....
Cheers Ross
I would think that you couldn't ever use FP1 equipment on anything other than an FP1 due to the much discussed gear pitch issue. That would be an absolute restriction.
As far as not being able to install heads other than the original NC vertical.... I have no basis for saying one way or the other, but it feels like this would be a restriction that would have weakened the conceptual flexibility of the machine. For instance, why shouldn't you be able to attach a shaping head or grinding head? And a long reach might have some use too... It just feels like Deckel would have wanted to preserve the feature, especially because it would be so easy to do so. But, maybe I'm wrong....
Alan
The riser will fit and can be driven (perhaps) but it will clatter and sound like its destroying itself...Save your effort..been there done that....
Cheers Ross
For my curiosity...do the drive gears not engage at all....or might, but would run noisey and wear quickly ? or ?For the FP1 vertical head, I can positively answer : NO.
Interesting.... did you get my email earlier today ?I have some long arm vertical heads for a FP2
Peter from holland
OK, was afraid of that. Re the FP2NC head swap...I just now took my first serious look at that possibility, and that idea is out even if the gears engaged ok (and even if I was willing to rig up a separate hydraulic unit to operate the drawbar) The unexpected reason is not the dovetail size but the total width of the ram is such that it would not clear the dial or handwheel of the horizontal quill. Also it would look ridiculous.They will engage but sure you'll know something's wrong as soon as you turn the machine on.
Interesting.... did you get me email earlier today ?
Notice
