OK to run FP2 with vertical head attached and horizontal spindle removed?
ballen
Sep 25, 2011
Garbsen, Germany
I've decided to open, clean and grease the horizontal spindle of my FP2. Now that I have it out, I need to make a couple of special wrenches. I'd like to use the vertical head on the FP2 to do this, but with the horizontal spindle removed. Does anyone see a problem with that?? I will of course plug the 80mm hole in the front and the 38mm one in the back to keep oil in and dirt out.
As far as I can tell, the transfer gear (which moves power from the headstock/ram up to the vertical spindle) is entirely supported by two 6010 bearings and does not get any support from the horizontal spindle. So having the horizontal spindle out should be no problem.
Hi there Bruce,
I might have the plug somewhere to save you from turning :P.
Did this last year, and it was for more than a few days. My reasoning said it was ok, and nothing strange happened in the meantime so I suppose is was really ok :)
Good luck on your overhaul.
BR,
Thanos
Hi Thanos,
Thanks. I made one for painting, but then converted it to a 6010 bearing puller, then lent it to Karl. I'm just going to use some masking tape.
That's reassuring, thank you!
I'm going to study your thread and Ross' thread for pointers. So far I am seeing signs that Bubba was here already (for example the nut on the spindle has badly beaten-up slots, which I am now making a proper wrench for).
In the worst case, I pack all of the bits in a box and send it to Uncle Franz for some TLC :).
Cheers,
Bruce
I am sure you'd do a better job than me but if, for a reason, you need the wrench for adjusting the bearings, I can send it over.
BR,
Thanos
OK, confirmed, the machine runs fine with the vertical spindle and no horizontal spindle.
attachment.php
