Deckel FP50/CC
The move from shop 1 to shop 2 was good. I had a great time learning how to run the machine and learning the D11 interface. Extra care was given to the PLC box to make sure it was handled carefully. The machine was unpowered for about 1 month and put back together in the new shop. All electrical wires are connected.
Now that it is has power and is on (along with my Hardinge Superslant!) I am getting a dreaded SPS: 0000 Selbsttest gestoppt: Zu viele Fehler or Selftest Stopped: Too many errors. From looking around, Wiggo is the only person who as done something like this (not 100% up to speed on that).
My current plan is to:
1. Look inside the PLC to see if there is any obvious damage. Maybe a loose wire or blow cap or something like that would be a miracle. Sometimes take apart and put back together works (please be so).
2. Check all batteries and see if they are dead. Maybe the loss of power caused it to lose BIOS info. I have a copy of the settings, but that is all. May need to flash the BIOS, which would also be scary. Not sure how to do that either.
3. Last plan of action. MESA card with LinuxCNC and a PC. I have experience getting home built 3D printers, and lunux cnc on a laser cutter, and two XYZ cnc router tables, but I know that three stepper motors and end stop buttons are far easier than a Deckel. I am leaving my current work so will have much more time in the shop so I could do it. Spend a few months testing each wire, finding the IOs, reading the manuals, writing scripts to change tools, speed, spindles, ect. Is or has anyone else done this? Also, is there a value in a broken D11 PLC?
Another note on this machine. There are new servos and servo drivers installed in 2002 I believe from the notes I have.
Does anyone have any first pointers of what I should do in this situation?
Also, dumb side note, the Hardinge Superslant that I bought from my work now says 'X axis locked' and wont let me start up the pump. The jerbs I have to do to get things running are piling up.
