OT- Got literature on 1998 vintage RSF glass scales ? Need signal type info
Results 1 to 11 of 11
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,353
    2824
    5645
    Default OT- Got literature on 1998 vintage RSF glass scales ? Need signal type info
    and pin outs would be nice. Scale model is MSA6701.... other info on the reader head data plate that may or may not be revelant.... spec 899A, K10, Int 20um, RI code 02U +5V. This on an Austrian made tool presetter (KPT Diaset D350) where the original control panel has crapped out. Would be nice to just bypass it and have a newer model Acu-Rite or Heidenhain display.
    FWIW, Current plugs are standard D sub 9 which is what newer Acu-Rite use but when connected to an Acu-Rite 200S get no signal.
    GERMANY
    2,758
    1736
    973
    According to Franz Singer's web page, your RSF scale is a pin-compatible replacement for a Heidenhain LS403 scale:
    Massstab MSA6701, 470 mm im Austausch von RSF
    The LS403 is an 11 uA sinusoidal 9-pin scale. So you should get hold of an old-fashioned Heidenhain scale and a DB9->9 pin round converter for testing.
  3. Likes Milacron liked this post
    Nov 2004
    SLC, UT
    701
    904
    139
    Need a photo of the nameplate data off the scale- not the reader head- to determine a few particulars.
    Have some RSF scales here, the pinouts on the same style connector as Heidenhain are usually not the same.
    Have to pay close attention with RSF as they make a lot of variations- pretty much every conceivable output format- square wave TTL or sine, voltage and current domain, various resolutions. Not a good idea to just plug them into something that the plug fits.
    Could be mistaken but it's possible that scale linked at Singer was specifically modified (likely just via the correct wiring of the correct connector) to be a Heidenhain compatible replacement.
  5. Likes Milacron liked this post
  6. #4
    Dec 2000
    51,353
    2824
    5645
    The latest on this mystery is that the RSF scales are 1Vpp (according the plate on the scale rather than the head)...but have the wire colors and connector (D sub 9) of a TTL scale. And then there's the cute thought that even if by some chance I find an RSF 9 pin D Sub 1Vpp pin out diagram, that the manufacturer of this tool presetter might have chosen yet different wire combinations to connect to their special control panel !
  7. #5
    Dec 2000
    51,353
    2824
    5645
    Finally found some relevant literature that shows the MSA 6701 scale.. ..https://www.mavin.com/pdf/RSF_encoder.PDF.... but what are "sinusoidal micro-current signals" ? Same as 11uApp ? (also what is the difference in 1Vss and 1Vpp ?)
  8. #6
    Sep 2002
    People's Republic
    3,338
    275
    2188
  9. #7
    Nov 2004
    SLC, UT
    701
    904
    139
    Basically and very generally speaking, Heidenhain and RSF have 4 different signal transmission formats:
    1- Single ended TTL (square wave)
    2- Differential TTL 5 Volt
    3- Differential sinewave, current domain. 11uA is the most common since about mid 1980s, but there is an older version also
    4- Differential sinewave, voltage domain. 1Vpp or 1Vss (same thing just English vs German wording)
    There are others, including EnDat. There are close ties between RSF and Heidenhain that go way back, pretty sure Heidenhain owns RSF now (as well as Acu-rite and parts of the former Grundig, among others).
    11uApp means 11 micro Amps Peak to Peak.
    Generally speaking, RSF is similar signals but not always the same as Heidenhain and almost never the same wiring conventions/connectors/pinouts. RSF offers more variety in output connectors compared to Heidenhain, which are pretty standardized for a given signal format. On top of that there are specials and/or stuff gets customized by another OEM or end user for particular applications.
  10. #8
    GERMANY
    2,758
    1736
    973
    Quote Originally Posted by Milacron View Post
    What are "sinusoidal micro-current signals" ? Same as 11uApp ?
    Yes, they are the same. See the last page of the spec linked in post #5. It reads as below. This is effectively the same as the Heidenhain 11 microamp spec.
    Microcurrent Sine Wave
    7-16mA (11.5 mA typical) with
    1 k ohm resistor for A & B
    channels 2-8mA 5mA (typical)
    with 1 k ohm resistor for Reference
  11. #9
    Dec 2000
    51,353
    2824
    5645
    Ah.., success ! By ignoring Heidenhains wire color code and paying attention to the RFS colors and function associated with each, I soldered the wires to the pins a Heidenhain Dsub 15 wants to use and now the antique KPT presenter is displaying on a nice ND780 DRO .
  12. #10
    GERMANY
    2,758
    1736
    973
    Ah.., success ! <SNIP> now the antique KPT presenter is displaying on a nice ND780 DRO .
    Well done! Please could you spend a minute and post a table showing which pins of the DB15 were connected to which of the RSF colors? That will help the next person with this question.
  13. #11
    Dec 2000
    51,353
    2824
    5645
    Quote Originally Posted by ballen View Post
    Sure...
    For RSF 6700 series scales 1Vpp* or 11uApp with "uhf" cable (orange wire rather than pink). To use with Heidenhain DRO with 15 pin D Sub connector the RSF wire arrangement is as follows...
    1 Black
    2 Brown
    3 Green
    4 Yellow
    5 /
    6 Orange
    7 Red
    8 /
    9 /
    10 Violet
    11 /
    12 Blue
    13 Internal shield*
    14 /
    15 /
    *1 Vpp seems to need no internal shield wire
  14. Likes ballen liked this post
