Lumberjack
Hot Rolled
- Jun 3, 2006
- Sweden
Hi,
Since getting a Deckel with uni table in front of it the task of setting angles has climbed way up the "hot topic issues" in my garage.
I tried to google but not really found what i looked for. There is a lot of info about tramming, as in setting spindle square to table.
So I´d really appreciate some good practice advise as guide to choose a way forward.
I would imagine height gauges and sine bar would be the first go-to solution on general?
At the moment I´m lacking both of those, which indeed calls out to be addressed. Not only due to this Buuut.. It feels a bit slow worked.
How about these type of accruate angle gauges?
I do not have those either but just thinking about it my feeling is that it should be a fast move just selecting the right one/pair, put them on the table and sweep over with the indicator. And in my mind that would be (maybe almost) done before even one has found out which combination height gauges to use with the sine bar?
Also thought about to use two preciesly spaced balls on the table and indicting height diff with the Z-readout and indicator, essentially somekind of inversed sinebar. Or just even measure direct on the table.
I think in future I might be getting both as they don´t really replace each other. But I think also the angle gauges can be used in many other instances as well making themselves useful, like in the lathe and on the grinder etc.
Soo firstly
Is there a "good common best practice" to hit precise angles with the table?
Height Vs Angle gauges - thoughts / comments?
Angle encoders would of course be "da shit" but I have not found any encoders that would make things better/faster and still be within a reasonble budget. Still a bit too much - you get what you pay for I think.
Maybe I´m just over thinking it.
Soo firstly
