I must say that I'm dubious when I see the first insert mill he uses on the video.
The concept of the SF32 rely on three small retention balls I wouldn't totally trust for high loads.
For a light finishing pass in aluminium, ok... But for for large diameter tools or heavy pass... I'm dubious.
I've noticed that the force required to eject the tool greatly varies depending upon the kind of work that was performed.
Light after light work or drilling... but clearly more after more demanding tasks like milling.
That is, more demanding for a P18 wich has a 55mm - just a tad over 2'- diameter quill... So the limiting factor shouldn't be the SF32 in my case.
To me, it is a clear sign that the attachment or the retention balls "seat" themselves in the spindle under the load (and there's no provision for adjusting the retention force).
I've also noticed visible signs of light brinelling on the ledge of the retention slot, on several of my attachments.
All that has me wondering when I see SF32 attachments mated to big milling cutters.
That said, the SF32 is a great system for what it is, and it's really one of the highlights of the small Fehlmanns
