Reference problem Deckel FP4
Results 1 to 3 of 3
    Jun 2018
    NETHERLANDS
    Red face Reference problem Deckel FP4
    Hi all
    We have a Deckel FP4A with Contour 2, But we have a little problem with it:
    When i shut down the machine, next time when i turn it back on i have to go to reference points on the X,Y and Z axis, otherwise i can't run a program.
    But when i move all axis to reference, it tries to go to the reference points but it stay's just a little before the reference point (like 0.015mm) and it shuts down the control power, error code : 17 Geschwindigkeitsfehler Y-Achse (Speed fault Y-Axis)
    Sometime also Geschwindigkeitsfehler X-Achse or Z-Achse.
    So now i switch control power back on (green push button), and move the axis away from end switch,
    Now i run the reference cycle again, now the machine switch off the control power at 0.010,
    Now i repeat step above, en machine switches off at 0.005
    Now i repeat it again, and machines is referenced.
    The problem is with all the axis but sometimes 1 or 2 axis have no problem and the 3 axis is the problem.
    I will upload a video in on Youtube quick.
    I hope somebody can help me.
    Dec 2002
    Benicia California USA
    7,475
    1531
    1793
    Interesting!
    Would try this....Clean all the tachometers...Alcohol with clean wipes till the wipe comes up spotless....
    Try doing the initial reference with the feed override turned down at 5-10%.
    If that helps, might need to check the tachometer and offset adjustments on the Bosch drive...Not sure how this is done on your Contour 2....
    Cheers Ross
    Jun 2018
    NETHERLANDS
    I didn't see that there was a new message so excuse me for late respons, but here is a link to the video posted on youtube: Reference problem Deckel FP4 - YouTube
    I allready tried it on differend feed override %, but is does't make any differance
    Where can i find the tachometers?
    I am thinkin that is has to do with the offset of the bosch drive, because it happens on all the 3 axis
    Greets Frank
