There are several transformers inside the machine control cabinet, check the voltages there.
Most transformers have +/-5% taps, usually you can get things dialed in just using the transformers in the machine, but if you can't, then you can use the taps on your external transformers to get things correct. Might require some experimentation - be careful and don't get shocked.
