deckeldoctor
Stainless
- Apr 26, 2005
- Conway,South Carolina
Hello All,
As of today there are 15 US,and 1 Canadian Deckel with LCD screens. They are on a wide variety of Dialog controls and one on a Contour 3.
If any one has an old dead CRT laying around I would be happy to get the frame, from it from you,I will pay the shipping for the frame.
If you receive an LCD from me you can remove the old tube and circuit board and just return the frame complete.This will cut shipping cost.
There are only 4 screws to remove the tube and 4 nuts to remove old circuit board.
As you can see the new LCD bolts in exactly where the old CRT was.There are no modifications necessary.
You have to remove a Rubber gasket that is directly in front of the old CRT to allow the LCD to be close to the glass of the operators console.
The replacement of your CRT should only take 30 minutes.Comes with complete instructions and a expaination of the on screen display (OSD)
There is a total of 6 phillips screws and 2 nuts.
The new LCD is plug and play.
You will notice in the one picture that now their is a small circuit board on the outside of the frame work where the old phenolic material covered the old board.
This board (pic 87) ON SCREEN DISPLAY (OSD)is where all the screen adjustments will take place,brightness,contrast,saturation,tint,sharpness,H-position,V-position, and backlight.
Depending on your lighting conditions in your shop you will only need to get it set to where it is most comfortable to your eyes one time, set it and forget it.
Once you see this display you will never want to look at another CRT. THis will be a problem if you have more than one machine.
There is a benzel on the front of the operators console behind this is a piece of tinted plastic if yours is scratched badly or you don't like look at the new LCD threw it, it can be removed by removing the 4 small button head cap screws that hold the benzel on the replace the bezel.
The manufacture says this LCD is good for 25-30,000 hours of use then it may need a new backlight which is a high voltage lamp that can be replaced for around $60.00US.
The price of the LCD is $900.00 US plus shipping and the frame of your old CRT.
The LCD will reduce the heat in the operators console greatly.
Regards
Deckeldoctor
[email protected]
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/Icd017.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010092.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010090.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010089.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010088.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010087.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010086.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010085.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010084.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010083.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010082.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010081.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/TFT%20LCD%20Screen/P1010080.jpg
http://i5.photobucket.com/albums/y155/doctordeckel/Image000.jpg
Regards
Deckeldoctor
[email protected]
