Thiel Duplex 155
Page 1 of 2 12 LastLast
Results 1 to 20 of 35
    Jan 2005
    The Netherlands
    5,631
    252
    1407
    Default Thiel Duplex 155
    I recently bought a milling machine Thiel Duplex 155 Mainly because I was curious how it was compared to the Duplex 159 the TH140 and TH150
    I thought to share a few things
    It has a seperate DC motor for the feeds and rapids and a typical transparent cover over the gearbox
    It turned out that the drive for that motor was connected completly wrong and even the electrical diagram is of no or little help if you have 2 different ones with the same number anyhow But with the help of my electronic goeroe it got solved
    It has a seperate oilpump with its own motor A bit loud BTW Acc. the dokumentation there was a option to have the Z-axe balanced with hydraulics using that oilpump Mine does not have that
    It has only powerfeeds and rapids on the X and Z
    XYZ is 350-200-350mm ,18 to 2500 RPM ant it has a quill with NT40
    Overall it is a nice machine Perhaps this was their budget machine
    At the looks of it perhaps the predecessor of the TH140/150
    Not as nice though
    What do you guys think of it
    A few pictures
    Peter from Holland
    BTW I am a machinery dealer so the machine is for sale
    Mar 2008
    Vienna Austria
    256
    86
    62
    Nice. Doesn't look like it has had to work very hard in it's life.
    Feb 2013
    midlands,UK
    3,153
    1625
    1538
    Interesting ,not heard of this model before nor the TH140 /50, what year is this machine Peterve? When did Thiel seize to exist? I believe the were taken over by Maho?
    Does this machine have a horizontal quill?
    GERMANY
    2,465
    1471
    828
    Hi Peter,
    This is a good-looking machine!
    Before I bought my FP2, I was close to purchasing a very clean TH150, but someone beat me to it. One cool feature was hydraulic locks on the three ways. Unlike the FP2, when you lock these down they do not slip! But as you know there isn't the same active marketplace for used and new parts, so I think it's harder to maintain them on a budget.
    What is that big "porthole" on one side -- is that a glass window into the inner workings? Kind of like one of those fine mechanical watches with a glass back to see the innards?
    Cheers,
    Bruce
    Jan 2005
    The Netherlands
    5,631
    252
    1407
    Quote Originally Posted by ballen View Post
    Hi Peter,
    Cheers,
    Bruce
    Bruce
    That could have been me
    I have bought a TH150 with hydraulic clamping in Germany about 5 years ago
    See this post Thiel TH 150
    That hydraulic clamping was a option BTW
    I had another one in 2013 that did not have that option
    Very genius way of clamping BTW It was a hose in a groove that was pumped up and that raised a clamping piece all over the lenght of the gib
    The lubrication system was used for the innitial filling of the hose and then just a bolt that was screwed in and out the system took care of the clamping and release action
    That porthole indeed is a plastic window to see the innerds of the machine
    some sort of oversized oilglass
    Sabre
    The electrical diagram has 1972 on it So YOM is eighter that or younger a couple of years
    The machine has no horizontal quill
    Thiel has a intresting history as after the war it was split up in fact
    you could eigter read up on Tony`s site Lathes.co.uk or German Wikipedia
    Both do not mention the end of the Thiel machines department
    Peter from holland
  6. Likes sable liked this post
    Nov 2011
    Norway - Akershus
    64
    9
    10
    Nice machine! I own a thiel duplex 158. fantastic build quality! How do you rank the different thiel mills? Ive seen that you have owned most of the models.
    Ola from Norway
    Feb 2013
    midlands,UK
    3,153
    1625
    1538
    I have a 158S and one noticeable improvement on this machine is the angle on the handwheel for raising the knee ,I find that quite awkward on mine ,especially as it is quite hard work to wind it ,is that usually the case or is there something wrong with mine?
  9. #8
    Nov 2011
    Norway - Akershus
    64
    9
    10
    Mine run quite nice. I guess using the quick feed if you have the 158s will make it a bit easier. However if you have the one eithout a sepeaprate feed motor maybe fitting one with a vfd could be an alternative?
  10. #9
    Feb 2013
    midlands,UK
    3,153
    1625
    1538
    Quote Originally Posted by slektning View Post
    It does have the separate motor.... but it's burnt out.
    When I bought it the feed motor had been replaced with a new one ,I wanted the old one but it had been scrapped ,the new motor only lasted a matter of minutes so I think it may be under powered ,for most of what I use it for the lack of power feeds isn't that much of a problem but raising the knee up and down is a pain, another job on the "To do" list, also the feed gearbox leaks pretty badly so that needs sorting as well.
  11. #10
    Nov 2011
    Norway - Akershus
    64
    9
    10
    Sounds like something is wrong with the z axis. That could explane the motor.
  12. Likes sable liked this post
  13. #11
    Jan 2005
    The Netherlands
    5,631
    252
    1407
    Ola
    The 158 is obsolete with its MT5 spindle. I don`t buy those anymore But if you can live with the MT5 and have enough tooling with it you have a great machine for a low price
    The Duplex 159 is the best designed toolroom milling machine for me
    Perfect quality Great design details like the tapered noniusrings the clamping mechanisme of the overarm
    The powerfeeds on the quill Even the gearboxes you can remove the lid and all parts stay in place
    The TH140 and 150 are from a more modern design with a smaller footprint Perhaps a bit more deckellike
    Very decent design but IMHO the 159 is the best
    peter from Holland
  14. #12
    Feb 2001
    Redwood City, CA USA
    4,894
    168
    852
    The 155 shares almost exactly the same specs as the Aciera F4, including short Y range and no power feed on Y.
  15. #13
    Nov 2011
    Norway - Akershus
    64
    9
    10
    I see! I have some holder and a fellow machinist with 2 158s mills will be making a batch of holders. Im also thinking of making a sandvik kosta toolholder for the mt5 taper. I have about 50 different holders for that so it would solve some problems. If you happen to stumble across a 158s parts machine or some accessories in very interrested. Do you know if the 158 and 159 have interchangable heads?
  16. Likes DJ2 liked this post
  17. #14
    Jan 2005
    The Netherlands
    5,631
    252
    1407
    I do not know if the heads are interchangable but I happen to have a head for a 158 for sale Its the one with the powerfeeds
    I don`t know if it works but its cheap
    Peter from holland
  18. #15
    Nov 2011
    Norway - Akershus
    64
    9
    10
    Could you send me a photo on slektning(at)gmail.com?
  19. #16
    Aug 2014
    Australia
    106
    33
    9
    Quote Originally Posted by peterve View Post
    Ola
    I really like the 155 Peter. I had the opportunity to buy a Thiel Duplex 159 about a year ago. It's the only 159 I have heard of in Australia. It had a spare slotting head. I went to the site to buy it and came home with a Deckel FP2. I reasoned that it would be too hard to find parts for the 159 compared to the FP2. I did get the Thiel rotary table however.
  20. #17
    Feb 2012
    GERMANY
    5
    Default Year of manufacture
    Hello,
    I'm intrested in all information about THIEL. My machine is a THIEL Duplex 158 S from 1964.
    Do you know the year of manufacture of your THIEL 155?
  21. #18
    Jan 2005
    The Netherlands
    5,631
    252
    1407
    You did not read all these posts isn`t it
    Post 5
    Peter from holland
  22. #19
    Feb 2013
    midlands,UK
    3,153
    1625
    1538
    Quote Originally Posted by mecanicus View Post
    Hello,
    How can you tell it is 1964? I have never found a date on mine.
  23. #20
    Feb 2012
    GERMANY
    5
    You must know, I've got all the papers which belong to the machine, also the test certificate, and there the date is written.
