SIP6A
Titanium
- May 29, 2003
- Temperance, Michigan
I was at the local machin tool dealers today picking up a cabnet that I had bought, when while the owner and myself were cleaning all the junk off of it and from the inside of it the owner picked up a wooden box and after opening it He says to me "You like this Swiss stuff you should have this" I ask how much and he replys "nothing it's a gift"
What they are is a fancy swiss set of set up blocks, There made like gage blocks the lock together in different combinations and yoe can go from 25.0mm to 300.0mm in 1.0mm steps. The last block is steel so on one end of the stack you have aluminum against the machine table and on the othe end you are clamping against steel.
