Tilt, Swivel, and Rotate Table VS Plain Table
Likes Likes:  0
Results 1 to 4 of 4
    Sep 2009
    washington
    240
    45
    Default Tilt, Swivel, and Rotate Table VS Plain Table
    Hello all,
    I was wondering why people who have both tables want
    to switch back and forth between them?
    Does the universal table just not have enough rigidity
    when compared to the plain table?
    Does it make a noticeable difference?
    Bridgeport's often go out of tram, does this same thing
    happen to the universal table?
    Paul
    Dec 2002
    Benicia California USA
    8,026
    1793
    2378
    Peter tells us that in Europe machines with plain angle tables are more sought after and bring a higher price than those fitted with the "2038" style tables
    Me, I have several of the "tool makers" tables (FP4NC, FP3NC and the rare small FP2NC plus one for my FP3 manual machine....
    I love them...IMO the best accessory that Deckel ever provided.....But that opinion is based on my use.....
    Rarely do much heavy cutting, and for my work the ability to use the table to bring into tram odd shaped parts is worth any loss of rigidity.
    As to staying in tram...maybe my sample is somewhat skewed....i move my tables often to adjust tram to the work and as such i do need to reset things from time to time,
    but really can't say that they need much attention unless there is a crash or you move them deliberately.
    Uni tables are also nice in that one can dial out any forward tilt or nod in the "Y" axis which happens in time from wear to all Deckels....
    Nice plus is that the universal tables also have center through holes that allow work on long shafts etc.....Further, you can see if things are moving...the tables are setup with indicators set to zero when the table is in tram,and rotary at "zero" so any movement shows on the dials..
    There are a few drawbacks to the universal tables...greatest is that in order to rotate the table 360* it must be mounted higher than the plain table, Loss of headroom in the order of about
    4.5" on an FP4NC. The factory fitted an extended hard strop and shorter travel "Z" limit cams to prevent the possibility of crashing the vertical head into the table surface....
    On my FP4NC i have omitted that extended hard stop and travel limit cam (i have mine setup with the standard table limit setup)
    Gives me max travel, but i have to watch for any interference to the table top with the vertical head.....Could be dangerous i guess, but for me its worth taking the extra care in watching my travels...
    Other down side is that the table work surface is reduced over the standard angle table ...On the FP4NC the 2038 top measures 17x28...While the standard angle table comes in at 21.5 x 17.5"
    Cheers Ross
    Jan 2005
    The Netherlands
    5,733
    264
    1445
    Those tables are heavier So the max tableload is less
    Also the distance between spindle and table is smaller with that kind of tables in general
    It is my believe that Deckel was very agressive in selling accessories compared to Schaublin Aciera and such
    That is why Deckel accessories are abundant IMHO
    So they sold the machine with a angle table and a universal table
    Then the universal table was put in the cabinet and never came out
    In the mean time the angle table got worn or the T slots broke out
    So universal tables are plenty on the market But many angle tables got machined in and got broken T slots
    Also all Deckel rebuilders want a angle table if they buy a machine from me
    Peter
    Mar 2015
    GREECE
    532
    148
    123
    Like Peter said....my angle table is also worn, while the tilting one is like new. So I keep that on..
    Miss the headroom sometimes though
