Wanted ! ! ! - Page 11
Page 11 of 23 FirstFirst ... 91011121321 ... LastLast
Results 201 to 220 of 441
Thread: Wanted ! ! !
  1. #201
    Jul 2009
    France
    17
    Yes I know It's gonna be hard to find one but everything is possible...I'm totally open minded on the color even a pink one!
    I hope I would not have to buy a second lathe to get it!
    Watch there is one for a 150 for sale here so why not one for a 135?
    Schaublin 150
  2. #202
    Dec 2002
    Benicia California USA
    8,364
    1951
    2706
    I would wager that it would be easier to rework the base of the 150 tailstock to fit your 135....
    Think the term "rare as hens teeth" applies here....
    Cheers Ross
  3. #203
    Oct 2010
    Maryland- USA
    4,267
    2172
    2644
    Wanted- bakelite hand wheel and stub axle for FP1
  4. #204
    Dec 2007
    Bad Homburg, Germany
    WANTED!
    Slotting Head for a Thiel Duplex 159.
    Cheers Axel
  5. #205
    Mar 2003
    Annapolis, MD USA
    66
    Default Aciera F3 Spiral Milling Gearbox Change Gears
    Need full set of Module 1 change gears (12 gears total) for old version F3 spiral milling gearbox.
    Last edited by Hunter; 02-22-2013 at 11:43 AM. Reason: Add Title, Change Subscription setting
  6. #206
    Dec 2004
    Cordova, Illinois
    308
    8
    9
    WTB: For a Deckel S1 grinder - I am in need of a SK40 dividing head. Any other parts would be appreciated too, but the dividing head is #1 priority. Any help appreciated!
  7. #207
    Apr 2004
    Monument CO USA
    2,080
    10
    122
    Default Aciera F3 Mod 1 gears source
    Don't know what the tooth counts are or what the hub looks like but presumably you have looked at Stock Drive Products selection of gear blanks. I was able to make a full set of change gears for my EMCO out of them pretty cheaply.
    Chris P
  8. #208
    May 2006
    Illinois
    268
    103
    56
    WTB draw bar for FP-1 vertical head. Machine is circa 1952.
  9. #209
    Mar 2003
    Annapolis, MD USA
    66
    Default Aciera F3 Spiral Milling Change Gears from SDP-SI
    Chris,
    Thanks. Yes, I have looked. There's good and bad news. I need only one each of most tooth counts so the raw gear stock is too expensive. Of their stock gears . . . The Aciera gears are 11mm wide with 1mm spacing steps on each side (essentially hubless - 13mm total width) and the widest SDP gears are 10mm which could probably be made to work, maybe adding spacing washers as needed. Hubbed stock gears would provide easy holding to open the bore to 17mm and possibly slot the keyways before cutting off.
    Most of their hubbed gears of the sizes needed are discontinued but there are a few of most sizes remaining in stock . . . reducing the price . . . the good news. Several are out of stock. Two tooth counts aren't available in any configuration.
    Depending upon configurations chosen, the total would be in the $300 to $400 range assuming the reduced price, discontinued gears . . . maybe a little more . . . with at least 4 gears still missing. The non-discounted (hubless) gears would add more cost.
    Since I have only one of the change gears (but have a list of the tooth counts of all), I'd like to know a little more about the full set before getting started. I've posted a thread asking for information about these gears and the gearbox housing (which I have), in general.
    Hunter
  10. #210
    Feb 2007
    Netherlands
    825
    101
    Quote Originally Posted by Milacron View Post
    I wonder if there has ever been a 135 starwheel tailstock for sale separately on the used market, anywhere on the planet ? I lucked out on mine as part of a deal buying two Schaublin 135 lathes.
    I recently found a 135 starwheel tailstock and added it to my collection. I want to trade it for a Schaublin 160 starwheel tailstock. Talking about rare....
  11. #211
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,459
    2925
    5744
    Quote Originally Posted by Kees View Post
    Holy Moses....if I needed one I would be salivating over it. What color...green or gray ? I keep meaning to paint my gray one green or silver hammertone to not clash so much with my green and silver 135 decor
    I still can't believe "T" thinks the gearing isn't ideal on those things...love mine. If only Fehlmann had made the quill section it would be the Holy Grail indeed.
  12. #212
    Feb 2007
    Netherlands
    825
    101
    Here you see the orphan:
    The paint has some wear, but it's working fine.No damage in the cone or on the quill, and gears are running very silent.
  13. Likes sporcu liked this post
  14. #213
    Dec 2000
    51,459
    2925
    5744
    Interesting that it looks like it used to be gray. Yeah the paint is funky but the steel looks excellent. That is one rare find. Is that your 150 starwheel in upper right or yet another ?
  15. #214
    Feb 2007
    Netherlands
    825
    101
    The upper right is a 150 tailstock, the part on the upper left is a taper turning attachment also for a 150.
    Years ago I knew about a 150 in a large factory, waiting to get the stamp "surplus".It had the standard tailstock , and was in a pristine condition. (BTW strange how many of those uber-expensive-when-new 150's have seen quit little use)Would make a perfect fit with this starwheel tailstock I already have . Hmm, maybe I should be more active to get this machine purchased, if it is still there.
  16. #215
    Aug 2011
    M.N. U.S.A.
    16
    Default Grinding wheel mounts for jig grinding attachment
    Looking for grinding wheel mounts for spindle motor with 5mm threads for jig grinding attachment.
  17. #216
    Dec 2004
    Cordova, Illinois
    308
    8
    9
    Quote Originally Posted by jtinkerer View Post
    Singer used to have those
  18. #217
    Jun 2011
    SWITZERLAND
    2,867
    649
    1217
    That looks (the paint does anyhow) like the tailstock that was offered with an Oerlikon or Reiden riser on Ricardo, at pretty much exactly the same time I was having surgery. Did you get that one? It was a good deal. Sadly I could not bid on that one at that time.
  19. #218
    Feb 2007
    Netherlands
    825
    101
    Quote Originally Posted by <jbc> View Post
    No, this one comes from East-Germany.Maybe the 135 tailstock on Ricardo went to Demoniakteam as he might be pretty close to Switzerland.
  20. #219
    Aug 2002
    France
    1,671
    296
    734
    Yep.
    There have been more 135 starwheel tailstocks offered for sale during the three last monthes than in ten years...
    Two on Ricardo and one on german eBay (wich I think is the one you have Kees (?) - otherwise, that makes a total of 4).
    You have a pretty cool collection now ! 125- 135- 2x150... Your shop is probably one of the highest Schaublin-starwheel-tailstocks/Sqm ratio places in western Europe !
  21. #220
    Jul 2009
    France
    17
    Yes I bought one of the 2 on Ricardo.
    I missed this one and the one which was on ebay kleinanzeigen which was obviously bought by Kees.
    And I get this one:
    It was something amazing, in one week there were 3 135 startwheel tailstocks for sale.
    Mine is not here anymore but I'm impatient to fit it on my 135.
    Charles
