Wanted ! ! ! - Page 21
Page 21 of 23 FirstFirst ... 111920212223 LastLast
Results 401 to 420 of 441
Thread: Wanted ! ! !
  1. #401
    Dec 2002
    Benicia California USA
    8,358
    1950
    2699
    All Dialog controls 2-4 were fully 4 axis capable. There are 4 slots in the operators console for axis cards (NZP)
    The fourth axis could be the NC dividing head , the NC rotary table or the encoder input from the "Tool Makers Table".....
    All fourth axis setups were i am pretty sure considered optional and not standard with the base machines.
    The EXE 610 box was only needed fro the encoder output from The Tool Makers Table, all the other 4th accessories connected directly to the #4 NZP board in the control.
    Machines fitted with the 2038 tables would have had the EXE 610 as its required to display at the control.
    Machine setups change over time...tables get installed and removed...Even though a machine might not have the 2038 installed it could have some time in its life, and perhaps
    the EXE box remained with the machine....its all unknown until you look in the bottom of the control....
    Cheers Ross
  2. #402
    May 2002
    South Central PA
    13,897
    2434
    3682
    I've purchased a number of EXE boxes on ebay, not exactly that one, but there are always plenty of them, often pretty cheap, and I've never received a bad one so far, so I guess they are pretty durable. Some dismantlers chop the cable off right at the bulkhead fitting, try to get one with a long enough cable to work in your application because the inside connector is probably difficult to source. I ~think~ the connector on the opposite end of the box is standard to all boxes. Also, I ~think~ some variants of the boxes use the same PC board inside with different settings on the DIP switches, so it would be smart to know for sure what the correct switch settings are for the box you need. There are documents on Heidenhain's site for each box that list the switch settings for various modes, but I'm not smart enough to understand all of them. Once the box is installed and wired up, it's easy to change the board in place if you suspect it's not working correctly at some point in the future.
  3. #403
    Jan 2003
    Imlay City, Michigan
    1,992
    102
    211
    Quote Originally Posted by AlfaGTA View Post
    Cheers Ross
    Thanks Ross, you helped to jog my memory! The machine the uni-table came off of had a Dynapath control, and a separate Heidenhain box for just the table.
    So it's unlikely I have one of these boxes?
    Kevin
  4. #404
    Sep 2002
    Salinas, CA USA
    4,154
    266
    232
    Ross, thank you for posting the photo. I don't know if this particular 2038-1100 table originally came on a FP3A or a FP3NC. I would like to verify that it has the 9000 line per rev. encoder before I buy the EXE610. We already know that there is an output when the table is cranked (the cable from the table is connected directly to the cable to the NZP). We also see output when we connect the table to a Heidenhain DRO. I have zero experience with Heidenhain DRO's... How does the DRO know to display degrees? Are there dip switch settings for that, along with the signal resolution?
  5. #405
    Nov 2004
    SLC, UT
    726
    961
    151
    Pretty sure the EXE box interpolates the signal from the rotary encoder and converts from sine wave format to TTL. Some, not all EXE boxes have internal settings like Mud mentioned. The NZP55 board ( Dialog control) has a DIP switch with settings to designate X,Y,Z or C axis display, when you set the DIP switch for C axis, the Dialog control knows to display degrees. Not sure about how things work with Dynapath.
    Would suggest extreme care handling the rotary encoders, they are a little exotic, very expensive to replace and expensive to repair.
  6. Likes AlfaGTA liked this post
  7. #406
    Dec 2002
    8,358
    1950
    2699
    To the best of my knowledge there are only a few of the Heidenhain DRO's that can actually display rotary encoder inputs as rotary elements (degrees and decimal degrees or degrees and minute/seconds.)
    Can be set via DIP switches or parameters depends on the DRO age....Got to go to the HH site and look at the user information for a specific DRO...
    Used to have a list when i was sorting all this out. Started when i got an "Aktive" FP2 with the "toolmakers Table fitted with the encoder.
    Machine came with a TNC113 Heidenhain DRO that could run the machine to stop at programmed points, but no way to actually display the rotary encoder...
    Finally found a sutible DRO that could do angles and piggy backed it above the TNC 113....
    The table that i got from an FP3-A having the 7200 line encoder is numbered 2038-500.
    Looks as though all the 9000 line encoders are 2038-800/1100/1200or 1300..................
    Cheers Ross
  8. Likes rimcanyon liked this post
  9. #407
    Sep 2002
    Salinas, CA USA
    4,154
    266
    232
    Ross, thanks for the detailed explanation. Still looking for the proper exe box. I found a few that might work, but they differ slightly in part number from yours. I went to the Heidenhain site and could not find any info on exe 610 series. They have an "Infobase" category, but search takes you to Heidenhain.de and requires a login account.
    Colt45, I found some documentation on exe 600 series, the input is sinusoidal, the output can be unclocked TTL or clocked TTL. Frequency varies.
  10. #408
    Nov 2004
    SLC, UT
    726
    961
    151
    Suggest determining exactly which encoder you have before buying the EXE box, will likely have a ROD or RON number, ie ROD 700 (thats the one in my NCT, the Universal table uses a different model). Most likely your encoder is sine output.
    There are at least 3 different Heidenhain sine formats, most likely you have 11 micro amp.
    There are a few different DIP settings on both switches on the NZP that relate to the rotary encoder, including resolution and continuous revolutions or single turn (360) display.
  11. Likes rimcanyon liked this post
  12. #409
    Sep 2002
    Salinas, CA USA
    4,154
    266
    232
    I made some progress with the infobase by going direct to heidenhain.de. Unfortunately there is no product information available for the exe 610 that is in Ross' machine. There is a general manual with lots of info (EXE 610, Operating Instructions German), but nothing that lists the differences between exe 610 models with very similar part numbers. However, and this is pure speculation, the general manual does have a table that explains the differences between 217 598 02, 03 and 06 (Ross unit is 09). The only difference being the type of 12-pin (output) connector. 06 is a Souriau Kupplung, and the diagram shows it being connected to Siemens controls, so perhaps 09 provides a 12-pin coupling that is specific to Grundig controls?
  13. #410
    Dec 2002
    8,358
    1950
    2699
    Don't know for sure, but believe specific part number could be to define the output cable.
    The connector for connecting to the NZP board is pretty specific for the Dialog boards....
    Other boxes that could easily be the same on the electronics might have different connections, that in the end might be changeable.
    Additionally, i can tell you that i had an EXE 610 fail! Not sure what the failure was to the box, but the result was that it killed the connected NZP board.
    Also be aware that there are different levels of NZP boards. ending i believe with the NZP 59 (Dialog 4) For use with the table encoder however the earlier Dialog 2 NZP's will work just fine in the 4th slot....
    Cheers Ross
  14. #411
    Mar 2005
    diamond ohio
    289
    65
    Hi all,
    My FP4Nc has the Nc indexer using the fourth slot with a NZP board and displays on the c axis. My machine doesn't have the box. My uni- table displays on a separate Heidenhain readout.Model # VRZ560 It displays in degrees, minutes and seconds or 3 place decimal degrees. the table is connected directly to it.
    Cave
  15. #412
    Oct 2019
    Oregon
    27
    Default Deckel FP1 Slotting Head
    I have been collecting some accessories for my new (to me) Deckel FP1 and I am still looking for a Slotting Head. You can email me at [email protected]
    Thank you,
    John
  16. #413
    Dec 2007
    Massachusetts
    392
    60
    Abene VHF-3 overarm support wanted.
    I know there's at least one spare out there in the world somewhere since mine's missing.
  17. Likes thanvg liked this post
  18. #414
    Jan 2015
    Virginia
    79
    66
    14
    If not could you order one from the company? I plan on ordering a spare belt and a speeds face plate for mine.
  19. #415
    Mar 2018
    10
    12
    Default WANTED - Deckel FP1 or similar mill
    WANTED:
    Deckel FP1 (older model from 1930-1940s would work just fine), Aciera F3, or similar universal mill (Sixis, Schaublin, Maho, etc.) in decent working condition. Smaller mills such as Aciera F2 (or Schaublin 12, etc.) would also work. Open to restoring one that might not be in great shape.
    I am located in southeast PA. Hence preference would be to find one within drivable distance.
    Thanks.
  20. Likes Laurentian liked this post
  21. #416
    Mar 2008
    Canada
    1,138
    6739
    209
    The FP-1 I posted in Montreal might be a good fir for you if ever you care to make the drive up with a trailer.. $3000 can is $2400 us 600V 3 phase might be an issue unless you're going to rewire single phase or other
  22. Likes homecnc liked this post
  23. #417
    Mar 2018
    10
    12
    Quote Originally Posted by Laurentian View Post
    I just looked at the picture of the old model FP1 you've posted on the "For Sale" thread. I think such a mill would work great for me. The 600V 3-phase "problem" should not be too difficult to solve (I'd probably just replace it with a 220V 3-phase motor). The main challenge is the long drive though.
    Let me see if anyone else in these areas has one to sell. If not, I will get back to you.
    Thanks.
  24. Likes Laurentian liked this post
  25. #418
    Feb 2013
    Greenfield, MA
    343
    57
    61
    WTB: Deckel Direct/close collets(40taper/Din574E)in Inch sizes or metric
  26. #419
    Jan 2008
    Cary, NC
    211
    95
    41
    Hi Chris,
    It probably goes without saying, but check eBay. They pop up from time to time from around $50 to $80.
    I just got 2 last week, actual Frederick Deckel brand even, 1/4" and 3/4". There was also a 5/8" one that I did not buy because I have that size already.
    You may also want to look at this CAT40 ER32 collet chuck on eBay:
    1PC High Performace CAT40-ER32-0.5- SuperRigid Collet-Chuck Tool-Holder-USA Sell 793574712263 | eBay
    I bought a few of those when I first got my FP1. I already had a couple sets of ER32 collets. This can cover most of your needs with very little Z-height loss.
    I believe Mari-Tool has something similar for a bit more money.
    Jacques
  27. #420
    May 2002
    South Central PA
    13,897
    2434
    3682
    I need the bridge ribbon cable that connects the top connectors on the NEP,NPP,NSP, and NSI boards in the Dialog operators console.
    Surely someone here has an extra?
