Wanted ! ! ! - Page 9
Page 9 of 20 FirstFirst ... 789101119 ... LastLast
Results 161 to 180 of 382
Thread: Wanted ! ! !
  1. #161
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,238
    2769
    5566
    Quote Originally Posted by Martin P View Post
    A whole bunch of NOS FP2NC chip trays hanging in my barns rafters. Since shipping would be an issue I suggest picking it up during your EMO visit in 3 weeks. Surely an event you won't miss?
    If one would fit in my luggage that would be tempting indeed. I took the pan off the FP2A last week to take it to a sheetmetal shop for them to duplicate it. But it was heavier than I expected and probably wouldn't fit in my little sports car, so I put it back, until I drive the truck to the shop again. Also I had forgot there is a bent pipe on the bottom for coolant drain, but I suppose that will be easy enough for the sheetmetal guys. But those complex bends I'm not so sure about.
  2. #162
    Sep 2002
    ohio-USA
    1,339
    85
    25
    Default wanted deckel g1L collets
    I'm looking for collets to a deckel g1L pantograph
    Markusfu at hotmail dot com
  3. #163
    Jan 2000
    South Carolina
    1,027
    187
    320
    Arrow Wanted-Deckel lamp.
    Prefer Waldman halogen type but would consider flourscent type if the connector is later direct to Y axis matching connector type.
    Milacron
    Email to [email protected]
  4. #164
    Dec 2002
    Benicia California USA
    7,938
    1764
    2294
    I rolled my own.
    Bought a Waldmann lamp, new off e-bay. Need 24v model.
    Got the connector directly from FPS in Germany. Milled up a little base to accept the original mounting bolt that fit up to the lamp base.
    Original Deckel work lamp is a joke. Can't see any real value unless you were working in a cave...that florescent thing is hard to tell even when its on...
    Cheers Ross
  5. #165
    Dec 2000
    51,238
    2769
    5566
    Quote Originally Posted by AlfaGTA View Post
    I rolled my own.
    Cheers Ross
    I have a proper size Waldmann already (came on a Swiss lathe long ago sold) but the mount is way different from the Deckel. The FP2A still has the long vertical post mounted on the top of ram, but needs a mount adapter and electrical connector. Do you remember what that connector cost ?
    The Waldman I have has a 110 to 24 volt "brick" in the wire assembly now...so the Deckel already has 24 volts at that connector and I can eliminate the brick for this purpose ?
    Of course this Waldman is all silver and doesn't have the proper "Deckel" logo on the light body but I guess it will do
  6. #166
    Feb 2001
    Redwood City, CA USA
    4,914
    169
    862
    What is the stock Waldman connector on an FP2NC flip-head supposed to be like? Is a plastic connector stock? My machine has a plastic connector on the lamp cord and plastic receptacle on the back of the ram. The latter is cracked, probably due to bending load on the relatively long connector hanging our there in space. If I ever get motivated to fix it, I'll just pick up a surplus metal military-style connector at Halted. That's what I did for the lamp on my Aciera F4.
    By the way, I had to replace the wiring running up the lamp arm and into the lamp housing. Between heat and some chemical, the copper was eaten away until one of the wires broke off the spade connector. I don't know whether the chemical was leaked coolant, leftover flux, or perhaps the product of plastic decomposition with hear. I know that PVC decomposes into some nasty stuff.
  7. #167
    Dec 2002
    7,938
    1764
    2294
    Rich:
    My receptacle is plastic on the body as well....4 bolt flanged mount.
    Bayonet pins on the receptacle are fitted on a metal band molded into the plastic body.
    My plug is metal with insulating guts. Has a plastic compression nut where the cord exits. seems to be made with lots of compliance between the coupling nut and the body...it is pretty long as well, about 3" or so.
    D: Been too long since i bought it can't say what it cost...bet it was expensive though.
    As to mounting the lamp...i just pulled the thread out of the vertical ram. Mace a little spacer block from aluminum , counter bored in the center to accept a bolt that fit the thread. Then i drilled and tapped holes at each corner of the block that matched the 4 holes on the lamp base flange....Bolt the riser to the head, bolt the lamp to the riser.
    Cheers Ross
  8. #168
    Switzerland
    6
    Default Deckel
    looking for a panthogarf with accessoires, and deckel fp1/2 accessoires
    "long-reach" vertical head
    fine-boring head
    or other rare heads with good prices
    i am located in switzerland, best your from swiss, french, italy or germany,
    near border switzerland.
  9. #169
    Aug 2004
    GERMANY
    1,710
    16
    288
    To R Klopp,
    the connectors are Burndy connectors (US) but apparently now sold under the Sourinau label.
    They are standard items:
    Connectors from Allied Electronics
  10. #170
    Feb 2007
    Central California, USA
    126
    6
    Smile Wanted: FP1 gearbox for spiral Milling Attachment
    Hello the Forum,
    When I purchased a Spiral Milling Attachment, it came with an FP2 Gearbox. I have an FP1 milling machine. I need an FP1 gearbox.
    I am interested to find someone in the reverse situation.
    I am willing to trade my FP2 Spiral Milling FP2 Gearbox for a FP1 gearbox. Decent condition, not new at all. Photos available to interested party.
    Stan Krumme
  11. #171
    May 2002
    South Central PA
    13,389
    2140
    3326
    Need a plug for a universal table to connect it to my FP4NC. The cord was cut off and discarded at some point while being stored. Is there one out there, or is there another connector that will work?
    jmagee at com cast dot net
    717-464-2800 days
  12. #172
    Apr 2009
    Michigan, USA
    40
    Looking for Aciera, Schaublin, Hermle, Deckel, or Maho mill. CNC or manual. Aciera would have to be at least F3 in size, Schaublin would be 22 or 13. Deckel Fp1 to Fp3, Maho MH300 to MH500.
    Sort of considering two mills. One would be CNC, one manual. Broken or project machines will be considered. The main constraint is that it is a garage machine, so looking for machines less than 6' 6" tall.
    constanw at gmail dot com
  13. #173
    May 2005
    New York
    57
    Default looking for a fp1 table in good shape
    Does anyone have a FP1 table for sale ? I'd consider a fixed or universal style. I just picked up an FP1 and previous owner overtightened the t nut holding the vise and broke a chunk out! Ouch thanks , Barry [email protected] cell 518 496-0123
  14. #174
    Dec 2002
    7,938
    1764
    2294
    Blade:
    Cheaper alternative is to make yourself a sub plate. Easy solution is to buy some tooling plate, and drill and tap a grid of holes in the surface...bolt it down to the table top and you are good to go.
    Cheers Ross
  15. Likes Laurentian liked this post
  16. #175
    Aug 2010
    Mt. Joy, PA
    135
    106
    36
    Smile Fp1 Table
    You could make a offer on the overpriced universal on EBay,if you bank account can stomach it. It might even be cheaper to deal with German EBay (shipping isn't all that bad) .
  17. #176
    Dec 2000
    51,238
    2769
    5566
    (aprox) 230/380 volt 3 phase transformers. 5 to 15 kva. Ideally the green Deckel types but consider any. Reply to [email protected]
  18. #177
    Dec 2010
    Sydney Au
    416
    41
    41
    Searched the Sourinau catalogue, size 8 and 12 are 3 pin, doesn't appear to match this..
    OD is 24.4mm, any suggestions?
  19. #178
    Sep 2003
    Amsterdam the Netherlands
    38
    Hello,
    Please post a picture of the deckel KF part, i have several parts for sale.
    thanks,
    HK51
  20. #179
    Dec 2000
    51,238
    2769
    5566
    WTB- Standard angular table for Deckel FP2, part 2210000300. Example of which in below photo..
  21. #180
    Oct 2004
    Denmark, Scandinavia, Europe
    732
    23
    51
    Hmm, isn't that the large table (for the long reach head)?
    My FP2 was born with that table along with the long reach head.
    AFAIR, the standard fixed table for an FP2 is the one that
    can be turned around to adjust the distance to the column.
    Cheers
    Erik
