Active tool violates programmed contour
? maybe not far enough away and when tool radius comp turned on it moves tool into programed line / arc. or its already into cut line/arc and tool comp moves it out
many cnc have parameter setting that alarms if this can happen usually stops before as look ahead sees the problem and cnc alarms.
that is it wants you start away from line arc go into line arc then when done move away from line /arc
It could be that your contour has an inside arc that is smaller than the tool after the cutter comp is applied.
