Contest for the most insane member (They will be a Maho owner) - Page 5
Page 5 of 5 FirstFirst ... 345
Results 81 to 96 of 96
  1. #81
    Jun 2016
    CANADA
    Alberta
    137
    24
    82
    ...and some photos as I've been progressing through... painted surfaces cleaning up well.
    Linear bearings cleaned, repacked with grease and rods cleaned up as well as I can really hope for. Slides very smoothly now.
    Quite a bit more work still needed on the sliding gripper assembly, I'll post more as I go through it. It is nice that the cylinders are all hydraulic and that the hydraulic system was still closed when I started. I mentioned earlier that I invested in new caps to plug each fitting as I took it apart and I'm glad I did because I don't have to deal with corrosion on any of the cylinders, especially the ones that were in the retracted position which almost all of them were.
    More to follow in the next few days.
    [email protected]
  2. Likes Panza liked this post
  3. #82
    Jun 2016
    CANADA
    Alberta
    137
    24
    82
    An update on the MC800H and the SL6B. Been working on both every day since my last post. The Mori is at my bay where I'm doing a run of long cycle parts so I'm working on it while machining. The MC800H is still at my home shop so I put in a few hours every evening as time allows.
    Mori SL6B:
    I've been still fighting the urge to repaint everything vs just the castings and paneling (Which are already done). The rear of the machine's paint is in pretty good shape so repainting is really only an aesthetic exercise at this point. I may opt for plan C where I build a booth over the machine and spray just the cabinets without removing them from the machine. I know I said I could never paint a machine without taking it apart but I usually don't paint inside the electrical cabinets anyway. This approach would be a good compromise between cost/time and appearance. Anyway, some photos of actual progress:
    I've removed the sliding tailstock base completely now and quite a bit more of the paint has been removed from the base casting.
    I removed the self contained pneumatic chuck...
    I'm pleased to report the special seals used to transfer air from the fixed ring to the chuck are in perfect condition. Everything will need to be cleaned but there is virtually no corrosion or damage of any kind which is a relief since replacement of that chuck would be very expensive.
    I will be completely dismantling that chuck to clean and lubricate its internals. I question the quality of the air that was used in the previous shop(s) where this machine was used so cleaning it and all the air system components gives me a great known starting point. As with the large Maho, I never even applied power to this machine before I pulled it apart. Trying to do anything with a machine that has sat for a long time, especially with some of that time outside will almost certainly do completely unnecessary damage...
    Here you can see the chuck and the stationary air ring removed as well as additional surface prep on the castings. Next I'm going to remove the sliding carriage assembly to inspect the turcite and remove old lubricant as well as any chips or debris that managed to get in there. At the same time I can closely inspect the condition of the way wiper lips. There is quite a bit of work yet to do on the Mori but besides general neglect there is nothing that can't still be in usable condition with a little care. I am concerned about the main spindle gearbox, that might have some issues as well as the internals of the turret and it's curvic coupling. I'll cover that soon.
    As for the Deckel Maho.... (Please see my next post)
  4. #83
    Jun 2016
    CANADA
    Alberta
    137
    24
    82
    The progress on the Maho has been unfortunately slow. When an assembly starts to become difficult when coming apart that is a good time to stop and give real thought as to how to proceed without damaging anything, so far I'm managed to stay patient enough to "do no harm".
    The sliding arm bearing in particular has been tricky. I acquired another puller and made some collars to get the end bearings removed so I could finally pull the shaft out. After that I was able to remove the shaft from the bearing and get it largely cleaned but the motion still wasn't smooth enough. I took the arm to my press and removed the recirculating bearing itself to see if there were any set screws which are accessed from the outside of the bearing that would prevent me from removing the ball guides.
    Turns out this is a THK Ball screw spline, one of the few Japanese made parts I've found on the machine:
    I've removed the seals and will be ultrasonically cleaning the bearing once I manage to get the retainer out. I've found a replacement for not all that much money in the event this one cannot be properly refurbished which is a relief. On Monday I'll call my local supplier and see what they are new.
    I don't think the shaft is in bad enough shape to warrant getting another one made from a THK supplied shaft. I've been toying with the idea of taking the shafts to get DLC coated to help prevent further issues down the road but that might be overkill as this machine will always be well serviced from this point onward, at least as long as I own it anyway.
  5. Likes Panza liked this post
  6. #84
    Jun 2016
    CANADA
    Alberta
    137
    24
    82
    Update on that ball spline assembly:
    The ball retainer inside the unit cannot be removed without damaging it. THK uses a permanent adhesive to assemble both parts of the retainer. After several attempts to try to get it apart I decided it wasn't worth damaging it so I cleaned the internals as much as possible and reassembled with fresh grease. It works pretty smoothly now.
    I assumed taking the pivoting arm assembly apart would be simple enough but I didn't realize there were quite a few hidden parts within that made the whole assembly a bit more complicated. After trying several approaches to get it to come apart I found the tool holder alignment lugs could be pulled from the end of the unit which allowed for a custom small puller to be made and used to separate the aluminum casting from the steel backing plates.
    Inside each side of the arm are a pair of fingers which can only be opened when a spring loaded pin/wedge unit is pressed from the side of the arm. This automatically happens when the arm is in the position of grabbing or releasing a tool. The advantage of this of course is that the tool cannot come out of the arm when it is not inserted in the spindle or tool changer.
    In the past this entire unit had the magnetic pickups for each linear movement set a little off I think, at least a couple of them. There has been minor markings on the ATC from when the arm tried to move when it shouldn't have been able to be given that instruction. One plate that retains the springs for the finger release wedge is actually damaged as part of it was ripped clean off (The plate can be seen in the middle of the picture above). I'll be making a new plate that will be either thicker or add another countersunk screw to hold it down so it can't lift and catch again resulting in the same damage.
    This is half way through the cleaning process:
    It is good to take the time to learn how each component is assembled and intended to function to aid in future maintenance when it is in use. Although this assembly will not require much maintenance it certainly will need a little TLC from time to time just to make sure no coolant has washed out the lubricant and started to cause problems. I'm confident the arm has never been apart since the machine was new.
  7. Likes Panza liked this post
  8. #85
    Mar 2006
    Vershire, Vermont
    2,059
    1325
    643
    I'm curious as to your cleaning methods and equipment. It always seems that cleaning represents a significant portion of the time required on a rebuild project like this.
  9. #86
    Jun 2016
    CANADA
    Alberta
    137
    24
    82
    Quote Originally Posted by neilho View Post
    Please see post 39 in this thread.
    The cleaning process on the MC800H is almost all of the time spent, made worse by the fact I'm trying to make it as close to new condition as possible without resorting to part or paint replacement. Some parts will be replaced and other parts will be repainted but I'm trying to minimize this.
    Today finally I completed the disassembly of the large sliding arm. It required some heat with a torch to remove the final stubborn key that was pressed into a hard to access ground shaft and I'm very pleased nothing was nicked or otherwise damaged in the process. There have been several parts found that would have contributed to ATC problems which makes the effort feel that much more worthwhile.
    On the Mori cleaning is becoming a balance between removing any corrosion/sludge/chips and actually removing the paint right down to the castings for repainting. I made great progress on the the Mori today and hopefully the Z axis saddle/ X axis slide assembly will be removed tomorrow.
    It is interesting to note that the Z travel on the Mori is restricted only by parameters, not mechanically (The ball screw has threading right until the box ways end). Because the chuck is so large (Z depth) the travel is reduced to prevent the turret from hitting the chuck body. For the work I do I'm seriously considering putting on a large diameter 4 jaw manual chuck which would be much "thinner" and increasing the travel to suit. I would much prefer the extra grip and adjustability as well as peace of mind of the 4 jaw over the faster self contained air chuck. We'll see what happens... I would love to hear what others think. I will be using this machine for API threading up to 16" material and larger solid round bar.
  10. Likes Panza, CBlair liked this post
  11. #87
    Oct 2009
    Oregon
    4,425
    4760
    2290
    If you are not doing a bunch of the same parts then a manual 4 jaw makes sense to me.
  12. #88
    Mar 2006
    Vershire, Vermont
    2,059
    1325
    643
    Quote Originally Posted by Nerv View Post
    Thanks! Ditto that on time spent....
  13. #89
    Jun 2016
    CANADA
    Alberta
    137
    24
    82
    This message is for "hanermo" who has a full inbox at the moment...
    You mentioned early in this thread that you have experience with old school computer challenges like what I'm dealing with in regards to the VME-based control on the MC800H I'm restoring.
    I have that same control on my DMU50V and I'm trying to get away from the HDD it has now to get something more SSD. I read about items like this:
    Transcend 8GB IDE PATA 2.5" SLC Internal Solid State Drive SSD Model TS8GPSD520 - Newegg.com
    and this:
    YouTube
    and I wanted to get your feedback. I also found some VME blades that have large SSD's too:
    VME SAS/SATA Solid State Disk Module | Phoenix International
    I don't need large internal data, I just want fast rear/write access if possible to improve performance during boot, loading and switching between modes. My main worry is getting the DOS based computer with it's old BIOS to recognize one of these options. Any feedback you have on this would be awesome. If it worked for the other MC800H too that would also be great since that memory is battery backed and I would prefer something that can't "die" per se. Then again, with a backup copy I prefer the fastest possible solution so maybe that EXM-2A Solid state card isn't a bad choice? It makes me wonder if I could "downgrade" from the HDD in my DMU to using the same EXM-2A. Less memory for programs (Which I don't use, I drip feed everything always) but faster performance?
    Obviously anyone that has feedback on this is welcome to put forth their ideas.
  14. #90
    Feb 2007
    Netherlands
    823
    101
    Make sure you make a copy/mirror of the HDD, one day it will go faulty and then you have a real problem.It contains among other software the unique parameters, PLC program and motorlist.
    A SSD wil not make your machine faster , the controller has a 386 or 486 processor and that sets the limit. A SSD however would be far more reliable but complex to get it running on the old VME controller
  15. #91
    Oct 2007
    SPAIN
    3,632
    2066
    1343
    Well i just read this through.
    Chapeau...quite mad!
    Keep up the good work!
  16. #92
    Jun 2016
    CANADA
    Alberta
    137
    24
    82
    After doing a bunch more board repair work lately I've placed my order for a Hakko FR-301 desoldering gun. To anyone else about to go through their CNC control boards pay the money first and save yourself a whole bunch of headache.
    Henry Ford's expression comes to mind: If you need a machine and don’t buy it, then you will ultimately find that you have paid for it and don’t have it.
    This is very true with desoldering, especially if the job is fairly large.
    I've been experimenting with blast media lately and have been using crushed walnut shells to clean delicate parts on the Mori lathe. I have a blasting cabinet and was very surprised with how mild yet effective the shell media was.
    I've since picked up a large portable carport/shelter to use as a "blasting booth" that the entire lathe can fit in. This will make cleaning the hard to access areas much easier and the walnut shells are pretty harmless on the precision surfaces.
    Here is the fan impeller from the chip conveyor motor before:
    ...and after the walnut shell treatment...
    This is very thick tar-like buildup that is pretty hard, I was shocked that the walnut shell didn't remove the paint but would remove such tough thick crud.
    Lathe is a slow-go but at least I have a great feeling about how well this machine will perform after I'm done. I've caught a few things that likely would have given me issues and the overall cleanliness of the machine makes working around it much more enjoyable.
  17. Likes petar712, Panza, BugRobotics liked this post
  18. #93
    Jun 2016
    CANADA
    Alberta
    137
    24
    82
    Well my Hakko FR-301 showed up today, just in time as I'm rebuilding a bunch of Fanuc drives and power supplies for a client. I know I said this earlier but now that I've actually used it I need to say it again:
    If you are doing any board work just buy one of these desoldering guns. It is worth every cent I was charged for it and I absolutely love it. I'm looking forward to finishing rebuilding all Maho Sr's boards with this unit. It makes the work a pleasure, really.
    Using my large-ish ultrasonic for cleaning IGBT heatsinks on the Fanuc drives also must be the best way to do it, I use "Simple green HD" in the U/S and although it isn't cheap it works amazing on aluminum and I highly recommend it too. Denatured alcohol works awesome too for certain things but also poses a serious fire hazard so I try to keep it's use at a minimum.
    I don't have much to show in the way of progress on either the MC800H or the SL-6B as I've been putting out fires for some other shops with broken down machinery. I've pulled all the power supplies from the Mori to go through them, everything in the NC cabinet has more corrosion on it than I've ever seen on a Fanuc... time will tell how much needs to be swapped out.
    Once all the electronic/electrical work is done on the Maho all that will be left will be finishing the ATC and APC assembly, getting the lower Z/Y combo telescoping way cover repaired and upgraded as well as getting the X axis way cover parts that are missing remade. I have a few panels that could probably use some new paint too. Maybe I'll actually see it run this year!
    In other news while I was ordering tons of electrical components for the Fanuc rebuild I decided to order the connectors I've been missing to be able to use my Siemens 802C control I purchased a little while ago, it looks identical to this:
    I've been seriously contemplating putting this control on the Tree lathe (soon) now that I've proven everything else on it works fine. The 'ol Bosch control has some serious limitations that the Siemens would take care of as well as provide me some additional useful capabilities, like thread repair.
    I would love to hear from anyone that has worked with the 802C, Siemens is unable to provide me with the necessary PLC software to setup the control due to it's age and they suggested I seek it elsewhere. For what I paid for this control (Brand new in box) you think it would have come with a CD with the necessary software. Besides that I think it will work well for the Tree lathe.
    Interestingly the version of the 802C I have doesn't seem to support the additional panel that has feedrate and rapid override via rotary switch, I would also be interested to know if anyone used up some I/O to put them in anyway in a custom panel. The control does have overrides via buttons but I don't know if I would like that all too much. The Grundig/Heidenhain Millplus control has spindle overrides via buttons as does Fagor 8055 and I don't mind, I do prefer the Fanuc Spindle override via rotary switch, even the ancient Bosch CNC Alpha has rotary switches for feedrate and spindle overrides.
    More to come as progress continues...
  19. Likes Panza, BugRobotics, snapatap liked this post
  20. #94
    Jun 2015
    Colorado
    511
    1053
    176
    Yea, those Hakko guns are really nice. Looking forward to more of the Maho build! Thanks for sharing.
  21. #95
    Oct 2009
    Oregon
    4,425
    4760
    2290
    Just wanted to say thanks for the desoldering gun recommendation. I love my Hakko irons, but never seen the desoldering stuff they offer. I had to replace several IC's in a drive and wasn't really winning with my old desoldering weller thing or any of the other old desoldering junk I had. So I found that FR-301 on Amazon with 1 day prime delivery and went for it. Best $245 I've spent in awhile.
    It actually makes desoldering fun. Typical Hakko it's built like a firearm or a space shuttle part. Really nice.
  22. #96
    Feb 2007
    Aberdeen, UK
    3,654
    1261
    1423
    Quote Originally Posted by Garwood View Post
    I have a super cheap and nasty desoldering gun, one of these:
    It actually works well, maybe a bit wanting for thermal mass at the tip, but pretty effective for through hole stuff. Are the Hakkos significantly better?
