Deckel Maho DMU50 Collet Removal
figured out that these come out from the bottom. a 5mm T-handle is used to loosen the center set screw then the collets can be easily unthreaded from the end of the draw bar.
SK40 Collet info
Purchase a collet tool, makes it simple. Make sure you get the dimensions correct, it’s stamped on face of the collet. Most often if German pull stud then 83.5mm but double check.
