DMG 64v linear, failure to home, X axis error code
Likes Likes:  0
Results 1 to 2 of 2
    Sep 2002
    People's Republic
    4,826
    503
    2936
    Default DMG 64v linear, failure to home, X axis error code
    Error: C3B0 Motor X does not rotate
    Which is funny because the x axis does not rotate...it is a linear motor....
    anyway, on the odd chance someone had a linear axis DMG machine and has had a failure, I cannot imagine what it is going to cost when a tech come in here and starts swapping parts out.
    Phone support guy says check the motor cable and encoder cable. Schematics are in German...
    History:
    owned since new 2003
    sporadic "axis has moved" errors on startup, since like forever, basically say OK and then enable machine, carefully move it a tad, then restart, "axis has moved" error, but this time with the correct numbers, carry on. Doing that for more than 7 years
    Recently gotten worse, more often, then if you do not reboot the machine instantly it emos and throws an error.
    I am sure there are few of these around, but its worth a try
    back to trying to absorb German wiring diagrams
    Sep 2002
    People's Republic
    4,826
    503
    2936
    Default resolution
    Found that this post came up on google, and not the one that actually describes the resolution of the issue:
    DMG Heidenhain absolute scale issues/resolution
    in case anyone trips over it
