DMG DMC 1035V Failed Tool Change and Alarms, Siemens 840D
Likes Likes:  0
Results 1 to 5 of 5
    Apr 2019
    Default DMG DMC 1035V Failed Tool Change and Alarms, Siemens 840D
    Hello everyone.
    I have a 2009 DMG DMC 1035V machining center (made in Germany) with a Siemens 840D Solutionline control.
    The problem Iím having is the machine stopped during a tool change with the tool change arm rotated 90 degrees from home position after having taken tool 1 out of the spindle and putting it back into the tool chain and putting an empty tool position ďintoĒ the spindle. Right about the time that the draw bar actuates the machine went into an E-stop alarm and stopped.
    I entered the manufacturer password to get to access level 7 and canít get out of E-stop or enable any of the drives in order to try to do the tool changer recovery process. The drives have 600VDC and 24VDC supplied.
    Iím hoping that there may be some PM members that can point me in the direction of working through this. Iím not sure if these errors are pointing to actual hardware failure or if the PLC is not enabling the spindle drive because the tool change arm is in a position that would cause damage if the spindle were to start turning. Any advice would be very much appreciated.
    Thanks for your help!
    Tyler
    Axis SP1 is the spindle.
    The alarms are as follows:
    25000: Axis SP1 hardware fault of active encoder
    25201: Axis SP1 drive fault
    201750: Axis SP1 SPI_DW_01 (16):
    SI Motion CU:HW fault safety-relevant encoder. 23609.
    201711: Axis SP1 SPI_DW_01 (16):
    SI Motion CU: Defect in a monitoring channelĒ. 0.
    27113: Axis SP1 hardware encoder error of the safe actual value.
    231125: Axis SP1 SPI_DW_01 (16):
    Encoder 1: Amplitude error track A or B overcontrolled. A-track: 32769, B-track: 32769
    700360: EMERGENCY STOP actuated or switch on control voltage by actuating illuminated pushbutton
    600314: Feed interlocking-Z: Changer arm not in home position
    701204: Exp_V_Interlocking: Main axes in Hopper area -> Relieve axes is necessary
    System info:
    PLC-No.: 4B0000_SCGR_01E
    NCU 710
    PCU50
    NC-Software : NCK_01.05_00.04
    PLC-Software : 4B0000_SCGR_01E
    Apr 2019
    Just to update here are some photos of the alarms.
    Attached Thumbnails Attached Thumbnails 20190413_173305-large-.jpg   20190413_173311-large-.jpg   20190413_200316-large-.jpg
    Apr 2019
    Default Update
    Update:
    I unplugged the encoder cable that comes from the spindle and plugs into the Sinamics Sensor Module SMC20 and I was able to go through the tool changer recovery process. The axis still will not enable but the E-stop condition is gone.
    207016: Axis SP1 SPI_DW_01 (16)
    Drive: Motor temperature sensor fault. 0.
    231120: Axis SP1 SPI_DW_01 (16)
    Encoder 1: Power supply voltage. Cause: 1b bin.
    231150: Axis SP1 SPI_DW_01 (16)
    Encoder 1: Initialization error. 0x100000.
    510205: Read-in interlocking: Spindle motor temperature too high
    Iím hoping someone has seen a similar series of errors and can help.
    Attached Thumbnails Attached Thumbnails 20190417_153110-large-.jpg   20190417_152927-large-.jpg
    May 2019
    Arizona
    6
    Send me contact info, I can help you out.
    [email protected]
    Nov 2020
    Alabama
    Quote Originally Posted by tr1gger88 View Post
    Update:
    Did you ever figure out the problem? Our gantry mill is having the exact same problem it seems.
