DMG mori NLX2500 Automatic tool presetter
Likes Likes:  0
Results 1 to 3 of 3
    Aug 2019
    Indiana
    Default DMG mori NLX2500 Automatic tool presetter
    Any one figure out how to use the automatic touch off arm on a double OD tool holder. The pre loaded program (9106) will not let you touch off when the Y axis is not zero returned. I have made changes to the program so I'm able to touch off in Z but not X. I can get it to touch off in X but I get a tool breakage alarm. I'm able to touch off manually.
    Jan 2014
    Oregon
    211
    37
    100
    Are you able to cycle start? What issue do you get?
    May need to change some parameters.
    6549.4=0 should disable checking Y axis position for cylce start
    6424.7=1 should disable checking Y axis position for presetter mode
    Aug 2019
    Indiana
    Yes I'm able to cycle start. I tested a different OD tool not in a double tool holder by putting Y at .002. It touched off X bad by .008. The double holder is off in Y -.462. Not sure if there is some kind of math equation that needs to be done in the program.
