DMU TNC 430 measuring system defective Y axis
Likes Likes:  0
Results 1 to 7 of 7
    Sep 2017
    POLAND
    26
    Default DMU TNC 430 measuring system defective Y axis
    Hi I have a problem with my DMU 103 V
    TNC 430 control
    I replaced the heidenhain measuring scale on the Y axis, I also pulled the belt on the Y axis motor
    and I have a big position -3634.019 the machine goes to the reference points but in manual mode when I'm driving the Y axis,
    the Y system defective error
    now I have to change something in the machine parameters to be good?
    I am asking for help in the pictures in the attachmentimg_5331.jpgimg_5332.jpg
    Sep 2002
    People's Republic
    2,402
    154
    1755
    Ok, chronology of your problem?
    why did you replace the scale?
    The error means the system does not like what it is seeing from the scale.
    does the display count when you move the scale?
    is it counting in the correct direction?
    Sep 2017
    POLAND
    26
    i replace scale becouse was defect and i change bearings on ball screw and I ripped the belt
    display shows ok when servo is off then i see looks good
    direction i good
    Sep 2002
    People's Republic
    2,402
    154
    1755
    I know the Heidenhain guys are very helpful over here, i would try whoever does heidenhain service over there
    they will know all the reasons for that error
    bad wiring or disconnected will get the error as soon as you enable the machine
    this 'feels' like it is not getting the readings the control expects, but I am not sure
    is the new scale 'exactly' like the old scale?
    Sep 2017
    POLAND
    26
    scale is the same
    the machine goes to points ok but all the time has high positions, and probably because the error pops up, I think it is out of the limit
    Sep 2017
    POLAND
    26
    I solved the problem, the cable from the ruler was damaged
    after replacing the cable, I show a good position thank you for your help
    Sep 2002
    People's Republic
    2,402
    154
    1755
    Quote Originally Posted by wojtekthx View Post
    Thanks for getting back with the solution, it will help people in the future with similar problems
