prl motorsports
- Jan 24, 2020
Has anyone successfully done this? I'm trying to do this on one of our machines due to wanting to turn the Mist Collector on with an M Code instead of only coming on with the Chip Blaster. I just need to be able to add a relay in the control and then from there, getting the mist collector to work is simple.
I've found on the power board where the Connection for M21-M25 connections need to be made, and i've been able to activate a relay, but those codes need an MFIN signal to move past them in the program, and when i've connected an MFIN signal from the relay, The M21 Code only activates the relay for a split second.
Hopefully someone can shed some light on this for me.
Thanks!
Jason
Thanks!
Jason
