Frustrated with Mori SV500 spindle unlocking on M00
Results 1 to 9 of 9
    Apr 2008
    Calgary
    50
    6
    Default Frustrated with Mori SV500 spindle unlocking on M00
    I have 2 1998 Mori Seiki sv500s made within a month of each other. I have a Haimler taster as tool #1 for setting work offsets. I use it to adjust offsets on every part sometimes. following will be some code as an example.
    The first mill will run this fine. It stops at M00, I hit offset button, change the offset, hit the mem button, hit the green button and away we go. Tool #1 is labeled a sensor tool in the control.
    If the sensor tool rotates for any reason, it will alarm. The 1st mill locks the spindle and door the whole time. The second mill unlocks the spindle and door on M00 and then sets a sensor rotate alarm. Is there a parameter to keep the spindle and door locked at M00?
    I had some great help for the Gentlegiant on the CNC Zone forum. I've compared the keep relay settings on both controls and they are the same. Gentle suggested I come here and ask this question, so here I am. Following is a link to my post at CNC Zone. I was unable to link for some reason. The title is the same over there.
    The control is fanuc 18iMA.
    O0000
    (OP1 G54 FRONT)
    (DATE 06-03-19 TIME 10:24)
    ( T4 | 1/4 CARB 3FL LOC=1.75 | H4 )
    N5 G20
    N10 G0 G17 G40 G49 G80 G90
    N15 G91 G28 Z0.
    N20 G30 X0. Y0.
    N25 T1 M6
    N30 G0 G90 G54 X-2.9 Y1.0 T4
    N35 Z1.
    N40 G1 Z0. F50.
    N45 M00(SET Z ZERO)
    N50 G0 Z2.
    N55 X-1.4 Y-.5
    N60 G1 Z-.13
    N65 Y0.
    N70 M00 (SET Y ZERO)
    N75 Y-.5
    N80 G0 Z2.
    N85 X-6. Y.3
    N90 G1 Z.3
    N95 X-6.464
    N100 M00 (SET X TO -6.464)
    N105 X-6.
    N110 G0 Z2.
    N115 G91 G28 Z0.
    N120 G30 X0. Y0.
    N125 M01
    ( 1/4 CARB 3FL LOC=1.75 | TOOL - 4 | DIA. OFF. - 4 | LEN. - 4 | TOOL DIA. - .25 )
    ( CONTOUR 3 COUNTERBORES )
    N130 T4 M6
    N135 G0 G90 G54 X-5.6074 Y.8171 S2000 M3
    Oct 2016
    Iowa
    36
    7
    What if you called the tool an endmill? I use a 3d sensor on all our machines and never lock the spindle. I just make sure that the dial faces the operator when it gets loaded into the spindle.
    Sent from my SM-G965U using Tapatalk
    Oct 2016
    Iowa
    36
    7
    Or if you want the spindle to stay locked in a certain position try using M19 S?? For spindle orientation angle.
    Apr 2008
    Calgary
    50
    6
    Quote Originally Posted by ktmktmman View Post
    I've mistakenly spun the spindle to 10000 rpm with a dial indicator, its not pretty. With it labeled as a sensor tool, it will never see any revs.
    Apr 2008
    Calgary
    50
    6
    It is locked until M00 is called.
    Oct 2016
    Iowa
    36
    7
    Have you tried dmg mori service? They will set you up with a tech and maybe you could download the parameters from each machine and see if and what is different?
    Apr 2008
    Calgary
    50
    6
    I could contact them, and I might, but then what would I learn. The more one understands their machine and how it works, the better.
    Jun 2015
    Minnesota
    248
    6
    81
    Go to your Sensor Setting screen, if you have it, hit (CUSTOM key - TOOL soft key) and enter the number of your Sensor Tool into the Sensor 1 area by moving the cursor, entering the value and hitting the SET soft key, then EXIT. According to my Operation Manual 1, the following happens. (MSC518)
    "With this setting, the sensor tool interlock function becomes valid when a sensor tool is mounted to the spindle to disable automatic and manual spindle rotation."
    Don't concern yourself with Spindle Tool and Empty Pot on the same page. Unless there's been trouble, these should take care of themselves. Sensor 2 is obviously for if you're running two Spindle sensors.
    Hope this helps.
    Apr 2008
    Calgary
    50
    6
    I broke down and talked to David at DMG Mori today. He was able to resolve this within minutes. I changed parameter K461 from a 3 to a 1. Hopefully this will help the next person.20191016_110948.jpg
  10. Likes TeachMePlease liked this post
