Gildemeister CTX 410 Operator Door Interlock Issue
hotrod1442
Oct 4, 2013
Ontario, Canada
We are having troubles with our Gildemeister CTX 410's operator door interlock. It has occasionally had issues with the door not being able to open using the "unlock" button on the operator control panel, for the amount of times that it was happening we just used the manual override button at the interlock switch assembly. The problem has become constant, so it's time to investigate further.
I guess I should detail a bit further, the (2)mechanical switches inside the interlock assembly that confirm "door open/closed position made", as well as the "latch open/closed" switch, both work properly, but there is no 24VDC signal going to the "unlock actuator".
Has anyone experienced this issue with their machine, and if so what was the cause/fix.
Thanks, Dave
