Heidenhain MillPlus IT V5
Likes Likes:  0
Results 1 to 1 of 1
    Oct 2008
    Denmark
    11
    Default Heidenhain MillPlus IT V5
    HI,
    I have a problem on my DMU 60P Deckel Maho mill, I have install a new X Axis motor and X Axis linear measuring scale.
    But my X measuring system in the MillPlus is now off by 0,2 mm fram the machine cordinal.
    I have been told that I can adjust the machine parameter 3125 "zero point setting"
    but if I change the value in this paremeter that makes no difference.
    To check I use a dial indicator in the center off the round table, and then du G53 and turn the round table 180 dec.
    I measure the new value on the dial indicator and is off 0,2 mm
    Can someone help me ?
    \CNC45
