se_jazman
- Mar 10, 2012
- Sandviken, Sweden
Hi everyone,
I am the owner of a MAHO 600E2, (year 1989), equipped with a toolchanger and an optional 4th axis Indexer. The axes have been switched on this machine, so the Y axis is the horizontal spindle axis.
The machine has been working fine, but I occasionally receive error Y09 (“dynamic following error”, “schleppfehler”). The error can appear at any position along the axis.
I first assumed it was the glass scale so I took it apart and cleaned thoroughly with isopropanol, both scale and reader. Also, checked all connectors and cleaned with electronic spray. However, the error remained.
The error is not consistent, and mostly appears after an hour or so. The machine can be standing still with hydraulics on, but I still get the error after a while. The somewhat unpredictable appearance of the error puzzles me.
The machine can also fault out by “freezing” the Y axis, while still possible to jog the X (horizontal) and Z (vertical) axis.
Turning off the machine clears the error. However, once it has appeared it is easier to recreate upon restart.
Setting machine constant 81 to show the dynamic following error, shows values of +/- 0.001 mm. However, when the Y axis “freezes” it stops at around 0.030 mm.
I assume there is some fault either in the measuring system, the measuring card, the servo drive or the motor. Checked the EXE-platine (impulsformer) by switching input/output between the X and Y axis, but the error still showed up for Y so at least that part is excluded.
I am planning to swap the TDM AC servo drives between the X and Y axes, and perhaps also do the same for the measurement cards since they seem to be the same types.
Does this sound like a reasonable approach?
I would be thankful for any ideas on how to further isolate the problem, or where it could be coming from.
Regards,
Stefan
Regards,
Stefan
